  3. Display Your Know How: Decoupling Capacitor
  • Replies 10
  • Views 7091
PCBTech
PCBTech over 1 year ago
The golden rule of decoupling capacitor placement is to minimize the distance between the IC’s voltage pin and the capacitor.
What about the routing of the capacitor to POWER and GROUND pins/planes!!
Which among the above decoupling capacitor routing configurations is better?
Any improvements that can be done?
Simply answer by letter or include any reason to support your answer. Alternatives and opinions are welcome!
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago
    None of these. Better may be like "C" but Power placed up to IX pin/right of capacitor pin.
    And depend aslo where the Ground pin of IC is located.
    This is for numeric IC. For analog one the answer differ. Problematic is not the same.
  • excellon1
    excellon1 over 1 year ago
    Are these caps Mirrored as in on the bottom layer of the board under a BGA. ?
    If that's the case then Picture C looks the best.
    Best Regards,
  • PCBTech
    PCBTech over 1 year ago in reply to JCTEYSSIER0
    Thanks for your insights, JCTEYSSIER0! I'd like to follow up on the placement of the Ground pin. Does its location have a significant impact on the decoupling capacitor routing?
    Additionally, how does the consideration change when designing an analog IC? Are there specific guidelines or best practices to keep in mind?
    I'd appreciate any thoughts or opinions on this matter, as it will help clarify the design considerations for Ground pin placement in both digital and analog contexts.
  • PCBTech
    PCBTech over 1 year ago in reply to excellon1
    That's correct, excellon1. The components are indeed placed underneath the IC, specifically on the bottom layer of the board.
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to PCBTech
    I have had SI engineers request the the routing go from the pin to the cap then to the via:
    if I remember correctly they thought this reduces Ground Bounce type of issues
