  3. Global Line Width Change
  • State Verified Answer
  • Answers 1
  • Views 5622
EO202501307419
EO202501307419 over 1 year ago
I wanna change some of my line width globally. I have heard about cwidth, but I dont know to use it. When I write it in command line, Encounter with command not found.
Any help?
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to EO202501307419 +1 verified
    Invoke the 'change' command Then in the Options tab disable everything except Line Width: & set the Width Then in the Visibility tab enable all the 'Etch' layers Then in the Find tab set the Find…
  • excellon1
    0 excellon1 over 1 year ago
    The command to change the line width is change width, however for the command to work you have to select the lines first so they are highlighted.
    Try the following.
    On your design in the find filter check clines and cline segs, Next window select the area that contains the traces you wish to change. Hover over one of the highlighted elements and right click, choose change width and enter a new width you want to use for the clines etc.
    Best Regards.
  • EO202501307419
    0 EO202501307419 over 1 year ago in reply to excellon1
    So, there is no way to change width based on a net name for example? Globally
    Or is there any way select a route based on the net name, instead of window select?
  • DavidJHutchins
    +1 DavidJHutchins over 1 year ago in reply to EO202501307419
    Then in the Find tab set the Find  Filter to 'Clines'
    Then in the 'Find By Name' pulldown select 'Net' and 'Name'
    Finally in the > Entrybox enter the net name...
  • EO202501307419
    0 EO202501307419 over 1 year ago in reply to DavidJHutchins
    THANKS
  • andakConsultingLtd
    0 andakConsultingLtd over 1 year ago
    Hello there,
    First of all, be aware that changing line around shapes could lead to unexpected results,so you might want to move the shapes outside the board.
    Secondly, you might also want to disable DRC check to improve speed.
    Now, to your problem, if you don;t want to go down the path of the SKILL scripting, you can use query to do acomplish this. This is somehow in line with what was mentioned below, but I think it is closer to what you need:
    in orcad pcb interface (not presto) edit->change
    under optiond do the changes as you need
    on the find tab, click select Find by Query
    select clines or cline segments from the objects list
    from the fields select what you need (nets) and move it to the right
    double click Net Equal To "*"
    select the nets you want to be affected amnd move them to the right pane
    select (you can hold shift) the items from the table to change the width
    you might need to rerun the query a few times. it may look chaotic when you first try to use it.
