  3. report file
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Views 5389
report file
masamasa
masamasa over 1 year ago
hello:
some report files have the xy locations which have a link to the exact location.
for instance i can click the xy coordinates highlighted in blue and automatically i am pointed into the location.
however, some other report files do not have a locational link.
for instance, there are xy coordinates on the report file without a link to the location as shown below.
is there a way to list up the xy coordinates with a link to the locations on all report files?
regards
masa
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to Hoangkhoipcb +1 suggested
    I updated my code to fail if the file type is not "rpt" & to not process the files that are already written in the 'new' format example messages: ERROR: file type html not supported with this tool…
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hi Masa,
    You can refer this code.
    axlCmdRegister("rpt2log" 'rpt2log)
    (defun rpt2log ()
        rpt_path = axlDMFileBrowse(nil nil )
        if(rpt_path != nil && index(rpt_path ".htm") then
            println(rpt_path)
            header = nil
            content = nil
            inPort = infile(rpt_path)
            Out_File = outfile("./rpt2log.log" "w")
            while(gets(nextline inPort)
                if(length(parseString(nextline)) >=1 then
                    nextline1 = car(parseString(nextline, "\n"))
                    if( nextline1 != ""  then
                        str_line = car(parseString(nextline1, "\n"))
                        if(index(str_line "<tr>") then
                            tmp_list = nil
                        else
                            if(index(str_line "</tr>") then
                                if(length(unique(tmp_list)) >1  then
                                    content = cons(tmp_list content)
                                tmp_list = nil
                            else
                                if(index(str_line "<td") && index(str_line "</td>") then
                                    pstr = cadr(parseString(str_line ">"))
                                    pstr = car(parseString(pstr "<"))
                                    if(pstr =="&nbsp;" then
                                        tmp_list = cons(" " tmp_list)
                                    else
                                        tmp_list = cons( pstr tmp_list)
                                    if(index(str_line "<td><b>") then
                                        pstr = caddr(parseString(str_line ">"))
                                        header = cons(pstr header)
                );end if
            );end while
            close(inPort)
            if(header != nil then
                header =  reverse(header)
                col_short = list("PIN_X" "PIN_NUMBER" "PIN_Y")
                foreach(item header
                    if(member(item col_short) then
                        fprintf(Out_File "%-12s" item)
                    else
                        fprintf(Out_File "%-30s" item)
                fprintf(Out_File "\n")
                foreach(item content
                    col = 0
                    foreach(str reverse(item)
                        if(member(nth(col header) col_short) then
                            if(nth(col header) == "PIN_X" then
                                fprintf(Out_File "(%s " str)
                            else
                                if(nth(col header) == "PIN_Y" then
                                    fprintf(Out_File "%s) %-10s" str " ")
                                else
                                    fprintf(Out_File "%-12s" str)
                        else
                            fprintf(Out_File "%-30s" str)
                        col++
            close(Out_File)
    HoangKhoi
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to Hoangkhoipcb
    example messages:
    Warning: file Net_Single_Pin_and_No_Pin.rpt is already in the new format
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/3857.rpt_5F00_update.zip
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to DavidJHutchins
    Thank you for your clear support.
