  3. How to add a white rectangle with black text in top silkscreen...
  • State Verified Answer
  • Replies 8
  • Answers 1
  • Subscribers 168
  • Views 5508
How to add a white rectangle with black text in top silkscreen layer?
msenick
msenick over 1 year ago
Using OrCAD X PCB Professional (OrCAD X 24.1).
I've been using Allegro in it's various revisions for many years, but this is the first time I have run into this: a client wishes for me to provide a small white rectangle on the top layer SS with black text inside the rectangle. How can this be done? I have tried using add>frectangle and then in display>assign color I assigned the color white to it, it shows up as white in the editor but not certain how it will turn out. Is there a known/approved methodology to add a colored rectangle with colored text to a SS layer? And also how about adding color for text, the display>assign color will not allow selection of text? Or must this all be specified in the fab drawing notes for fab house to implement?
Thanks.
  • excellon1
    excellon1 over 1 year ago +3 verified
    Hi, usually this is a dual process and is carried out either by the board manufacturer or it could take the form of a stamp that is applied at the assembly house in the white silkscreen area. The easy…
  • oldmouldy
    oldmouldy over 1 year ago in reply to msenick +2
    If you want "black" as the colour, you would need a stamp, but you can "reverse" text in PCB Editor to show a "box" in the Silkscreen colour and have the Soldermask colour shown, as described in this note…
  • steve
    steve over 1 year ago +2 suggested
    Although not exactly what you need this could also be an option :- How to reverse Text in PCB Editor
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to steve
    another possibility is to use the custom command 'text2shape' from skill code attached in the zip file to convert the text into shape(s) for each letter:
    text2shape t   ( the optional t enables the deletion of the text after the conversion to shapes )
    Then use the 'Shape->Shape Operations-> ANDNOT to remove the shapes for each character from the surrounding shape
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/text2shape.zip
    • Vote Up +2 Vote Down
  • msenick
    0 msenick over 1 year ago in reply to oldmouldy
    The fab house was ok with the original method suggested  in first response, so I went with it. Thanks!
  • Ulf K
    0 Ulf K over 1 year ago in reply to excellon1
    I have used the method of creating subclasses like "NEGATIVE_TEXT_TOP_ETCH" and when ordering boards specified that the manufacturer performs this subraction operation when preparing the files for processing. Using methodes like ie. suggested by Parallel systems work, but it requires careful attention to the appertures used when creating shapes. Also, texts created using that method are non-moveable.
