  3. How to add a white rectangle with black text in top silkscreen...
  • State Verified Answer
  • Replies 8
  • Answers 1
  • Subscribers 168
  • Views 5506
How to add a white rectangle with black text in top silkscreen layer?
msenick
msenick over 1 year ago
Using OrCAD X PCB Professional (OrCAD X 24.1).
I've been using Allegro in it's various revisions for many years, but this is the first time I have run into this: a client wishes for me to provide a small white rectangle on the top layer SS with black text inside the rectangle. How can this be done? I have tried using add>frectangle and then in display>assign color I assigned the color white to it, it shows up as white in the editor but not certain how it will turn out. Is there a known/approved methodology to add a colored rectangle with colored text to a SS layer? And also how about adding color for text, the display>assign color will not allow selection of text? Or must this all be specified in the fab drawing notes for fab house to implement?
Thanks.
  • excellon1
    excellon1 over 1 year ago +3 verified
    Hi, usually this is a dual process and is carried out either by the board manufacturer or it could take the form of a stamp that is applied at the assembly house in the white silkscreen area. The easy…
  • oldmouldy
    oldmouldy over 1 year ago in reply to msenick +2
    If you want "black" as the colour, you would need a stamp, but you can "reverse" text in PCB Editor to show a "box" in the Silkscreen colour and have the Soldermask colour shown, as described in this note…
  • steve
    steve over 1 year ago +2 suggested
    Although not exactly what you need this could also be an option :- How to reverse Text in PCB Editor
  • excellon1
    0 excellon1 over 1 year ago
    The easy road is to create a shape rectangle on the silkscreen and then add a fab note to indicate the location of the text within the rectangle. The Assembly house
    would add the text that is needed in black or any suitable color.
    You could also for the text create a new subclass on the "Board Geometry" Class and call it "SilkScreen2" and add the text there so it shows up in the PCB Editor.
    Look under "Setup > Subclasses to do this.
    Best Regards.
    • Vote Up +3 Vote Down
  • msenick
    0 msenick over 1 year ago in reply to excellon1
    Thank you! I had suspected as much as there didn't seem to be any available choices for it. I very much appreciate your help! Thanks and have a great day!!
  • oldmouldy
    0 oldmouldy over 1 year ago in reply to msenick
    If you want "black" as the colour, you would need a stamp, but you can "reverse" text in PCB Editor to show a "box" in the Silkscreen colour and have the Soldermask colour shown, as described in this note: https://www.parallel-systems.co.uk/wp-content/uploads/2020/02/Reversing_text.pdf
    • Vote Up +2 Vote Down
  • oldmouldy
    You can reverse the Text which would get you the Soldermask color. See this note: https://www.parallel-systems.co.uk/wp-content/uploads/2020/02/Reversing_text.pdf
  • steve
    0 steve over 1 year ago
