  3. Hybrid PCB Stackups: Why they matter and how to get them...
  • Subscribers 163
  • Views 657
Hybrid PCB Stackups: Why they matter and how to get them right - Part 2
Gowtham P
Gowtham P over 1 year ago
You’ve seen the benefits of hybrid stackups in Part 1 of this series. Now let’s talk about the real-world hurdles and how to overcome them without burning time or budget.
Material choices:
Material selection in hybrid stackups depends on trade-offs between electrical performance, thermal stability, and cost. The table below compares commonly used laminates to support informed choices.
Material Dk @ 10 GHz Df @ 10 GHz Tg (°C)
Notes
FR-4 ~4.2 ~0.020 130–170 Economical, but lossy at high speeds
Rogers 4350B 3.48 0.0037 280 Excellent for RF and high-speed digital
Megtron 6 3.3-3.7 0.002 185 Ideal for high-speed backplanes
Isola I-Tera MT40 3.45 0.0031 200 Good balance of performance and cost
Pro tip: Always check the datasheets of these materials for Dk and Df at your actual operating frequency.
Common design challenges and how to avoid them:
  1. Material Compatibility: Different materials expand at different rates when heated. If you mix materials with mismatched CTE (coefficient of thermal expansion), you risk delamination or warping during reflow or thermal cycling.
  1. Lamination Process: Some materials require different press temperatures and pressures. Your fab house needs to know exactly what you’re using so they can plan the lamination cycle accordingly.
  1. Impedance Control: If your signal layers are on different materials, your trace Impedance will vary. Use 2D Field solver in Allegro Cross Section Editor to model the Impedance accurately, and make sure your stackup is symmetrical to avoid mechanical stress.
Why your fabricator should be involved early?
This is critical. Hybrid stackups require close coordination with your fabrication vendor from the early stages of design. Leaving these decisions until the end of the process can lead to manufacturability issues, delays, or costly redesigns.
Here’s why:
  • Material Availability: Not all fabs stock Rogers, Megtron, or other specialty materials. Some have long lead times.
  • Process Capability: Not every shop can handle PTFE-based materials or complex lamination cycles.
  • Stackup Validation: Your fab can help you optimize the layer order, prepreg selection, and resin flow to avoid issues during build.
  • Cost Estimation: They’ll help you understand how your material choices affect cost and where you can save the cost without compromising performance.
Bottom line: Treat your fabricator like a design partner, not just a vendor. Share your stackup early, ask for feedback, and iterate together.
Hybrid stackups are a powerful tool in the PCB designer’s toolkit, but they come with complexity. The key to success is understanding your materials, simulating early, and working closely with your fab partner from day one.
If you’re designing for high-speed, RF, or thermally demanding applications, going hybrid might be the smartest move you make.
Comment below to add more design challenges you face while designing stackups!!
