  3. acute angle
  • State Verified Answer
  • Replies 10
  • Subscribers 167
  • Views 5874
acute angle
masamasa
masamasa over 1 year ago
hello:
is there a way to detect a location with acute angle shapes?
the edit property has a setting for the acute angle to avoid having acute angle.
but i would like to find the acute angle location on the deisgn that was made by our customer and has many acute angles.
regards
masa
  • steve
    steve over 1 year ago +2
    Yes, Setup - Contsraints - Modes - Design and then Acute angle Detection, set an angle andf type and enable the DRC to on.
  • masamasa
    masamasa over 1 year ago in reply to steve +1
    thank u for your response, steve. yes, it works for 90% of the cases. however, it does not work on the situation where a fillet creates an acute angle and a shape and a padstack intersect each…
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to masamasa +1 verified
    I think I have some skill code that will detect the via to shape issue, let me know if you want to try it...
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to MY202510076911
    I wrote some skill code to find these acute angles & add DRC flags
  • Xiaome8
    0 Xiaome8 over 1 year ago in reply to DavidJHutchins
    Hi David,
    Would you help to share this code? thanks!
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to Xiaome8
    I am now under contract with Arm Limited and cannot share any code
  • Xiaome8
    Noted,thanks any way.
  • DavidJHutchins
    below is the peusdo-code for the overall process:
    foreach(shape ListOfShapes
       (ShpPoly = car((axlPolyFromDB shape)))
       if(shape->fillet then
           axlAddSelectBox(shape->bBox)
           foreach(seg axlGetSelSet()
               (ExpPoly = car(axlPolyFromDB( seg )))
               (ShpPoly =  car(axlPolyOperation(ShpPoly ExpPoly 'OR)))
           (segs = convertArc2segs(ShpPoly))
       else
           foreach(via axlGetSelSet()
               when((((caadr(via->bBox)-caar(via->bBox))/2)) > Radius
                   (Radius = ViaSize)
           (ExpPoly = car(axlPolyExpand(ShpPoly Radius 'NONE)))
           axlAddSelectBox(ExpPoly->bBox)
               unless(axlGeoPointInShape(via->xy shape nil)
                   (ExpPoly = car(axlPolyFromDB( via )))
       foreach(seg segs
           (angle = axlGeoAngleBetweenLines(seg Lastseg))
           when(angle > 90
               axlDBCreateExternalDRC()
           (Lastseg = seg)
       (angle = axlGeoAngleBetweenLines(car(seg) Lastseg))
       when(angle > 90
