  3. Automatic PCB Router crashes on startup
  • State Suggested Answer
  • Replies 11
  • Answers 3
  • Subscribers 166
  • Views 6871
jritter
jritter over 1 year ago
Hi, i get the following error when starting autorouter in allegro.
I tried a reinstallation - this does not give a solution. Further the specctra files are both created, but empty.
Same project works without any problems on another system. My HW is a HP omnibook with amd ryzen ai 9. The other Laptop is Intel I5.  May this be the problem?
Kind regards
Julian
  • FaPb
    FaPb over 1 year ago +3 suggested
    I got this reply from support: Starting from version 22.10 ISR09 , the Cadence SPB installer no longer includes the "Microsoft Visual C++ 2012 Redistributable Package (x86)" that are required for the…
  • excellon1
    excellon1 over 1 year ago in reply to jritter +2 suggested
    When you install the software, choose all options even if you don't have a license for them. Hopefully after a new install all will work ok. Best regards.
  • excellon1
    excellon1 over 1 year ago +1
    Hi Julian, I doubt the issue is related to your hardware as I use a R9 here and its fast. It could be related to OS permissions. When you installed Allegro/Orcad did you install it as a current user…
  • excellon1
    0 excellon1 over 1 year ago in reply to jritter
    Best regards.
    • Vote Up +2 Vote Down
  • FaPb
    0 FaPb over 1 year ago
    Starting from version 22.10 ISR09, the Cadence SPB installer no longer includes the "Microsoft Visual C++ 2012 Redistributable Package (x86)" that are required for the SPECCTRA/Automatic Router to run. Users are expected to install it manually.
    When this redistributable is missing, launching SPECCTRA—either through "Allegro > Route > PCB Router > Route Automatic" or directly via "spectra.exe" from the installation folder—results in a crash with error code -1073741701, and both spectra.log and spectra.did files will be empty.
    This issue primarily affects new users installing Allegro for the first time, especially version 24.1.
    Please check if the user has re-distributable installed in his system. Check Control Panel > Programs and Features.
    Currently, the solution will be to install Microsoft Visual C++ 2012 redistributable package (x86) from the microsoft's download page. Installing it in user's system should resolve the crash issue.
    • Vote Up +3 Vote Down
  • excellon1
    0 excellon1 over 1 year ago in reply to FaPb
    HI FP,
    Thanks for the info on this. It's kind of hard to believe that a 6Mb file was pulled from the main installer.
    Best regards.
  • jritter
    0 jritter over 1 year ago in reply to FaPb
    As you can see all is installed, but still same error.
  • FaPb
    0 FaPb over 1 year ago in reply to jritter
    Ok, I have not tried yet.
