  3. Automatic PCB Router crashes on startup
  • State Suggested Answer
  • Replies 11
  • Answers 3
  • Subscribers 166
  • Views 6872
jritter
jritter over 1 year ago
Hi, i get the following error when starting autorouter in allegro.
I tried a reinstallation - this does not give a solution. Further the specctra files are both created, but empty.
Same project works without any problems on another system. My HW is a HP omnibook with amd ryzen ai 9. The other Laptop is Intel I5.  May this be the problem?
Kind regards
Julian
  • FaPb
    FaPb over 1 year ago +3 suggested
    I got this reply from support: Starting from version 22.10 ISR09 , the Cadence SPB installer no longer includes the "Microsoft Visual C++ 2012 Redistributable Package (x86)" that are required for the…
  • excellon1
    excellon1 over 1 year ago in reply to jritter +2 suggested
    When you install the software, choose all options even if you don't have a license for them. Hopefully after a new install all will work ok. Best regards.
  • excellon1
    excellon1 over 1 year ago +1
    Hi Julian, I doubt the issue is related to your hardware as I use a R9 here and its fast. It could be related to OS permissions. When you installed Allegro/Orcad did you install it as a current user…
  • jritter
    0 jritter over 1 year ago in reply to FaPb
    I am sorry, as you can see in the upper screenshot, i only installed the 64 bit version. When installed the 32 bit version of Microsoft Visual C++ 2012 redistributable package, it started working correctly. Thank you all for your support!
