  3. Differential Pair Setup of Class to Class
  • State Suggested Answer
  • Replies 18
  • Answers 2
  • Subscribers 168
  • Views 9372
Sagetech
Sagetech over 1 year ago
Trying to configure differential pair spacing from pair to pair and other traces.
I've been following the Parallel Systems Differential Pair tutorial but I'm not getting the results I need.
I have my diff pair trace width and spacing set up in the physical cset.
I set up a spacing cset and net class to get my pair to pair spacing constrained. When I do this, the pairs do seem to adhere to the pair to pair spacing constraint but I get a DRC on the differential pair line to line spacing set in the physical constraint. If I remove the spacing cset, the pair spacing DRC goes away but the pair to pair spacing is no longer constrained and I can route one pair too close to the next pair.
Been through the instructions a dozen times with the same result. Instructions were published in 2020, maybe things have changed since then?
Thoughts / suggestions?
Tom
  • Sagetech
    Sagetech over 1 year ago in reply to avant +2
    So if I have 50 differential pairs I need to assign a different "class" name to each - seems time consuming.......... I'm sure I don't understand all of the groups and class assignments and method…
  • steve
    steve over 1 year ago in reply to Sagetech +2 suggested
    You need to read the supplemental notes app (under the diff pairs one) on the same website and that gives you all you need to know about why you really should set tolerances and min line spacing.
  • Sagetech
    Sagetech over 1 year ago +1
    PS: Running latest version of PCB Editor 24.1
  • Sagetech
    0 Sagetech over 1 year ago in reply to excellon1
    Yes this does work, the diff pair to “other” spacing is now maintained – thank you.
    But……..
     When I set the “line to pin” clearance so that I can’t route within 18 mils of a pin (connector, IC, etc…), I get DRC’s at the connector where the traces connect which makes sense as they no longer conform to the constraint due to the picth of the connector pins. Is there a way to “allow” this?
     I suppose at the end of the day I can waive those DRC’s. Biggest hurdle for me was getting the trace routing to conform.
     Tom
    Was trying to insert a screen shot of the DRC's but keep getting errors. 84k file shouldn't be an issue.
    Pic just showed three diff pairs connecting to the connector and the DRC's of pin to line at each connection point.
  • Sagetech
    0 Sagetech over 1 year ago in reply to Sagetech
    Oh, and next up I need to constrain groups of diff pairs to be routed to the same length  +/- tolerance. I believe I can do that by making a net group for each group of signals and apply the phase tolerance to that group.
    Tom
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago in reply to Sagetech
    Depend of the reason why you want 18 mils. If only to avoid coupling with orher signal, i set 18 mils only for clien/clien, clien/shape and shape/shape. Coupling with vias and pin does not matter in such case (well, exeption occcure but this is the general case)
    Secong way is to creta locally region (say FANOUT_EXEPTION): in theses region use an other spacing set in order to no have drc. The bad side of this way is if a component is moved or deleted, the region stay in place and aslo the exeption.
    Waiving is ok until you have a few one (ssy, less than 10 and some small number: getting too much waived drc is dna gerous for me: how to insure that they are ALL still ok?
  • JCTEYSSIER0
    This is done with relative propagation delay constraint in electrical domain
  • avant
    0 avant over 1 year ago in reply to Sagetech
    If you are using the second or third license tier, you can create a drc "region" constraint.
    You can create a shape (rectangle) and assign the region constraint to it. Put this shape around pins, vias, etc, to override the general constraints.
