  3. Differential Pair Setup of Class to Class
  • State Suggested Answer
  • Replies 18
  • Answers 2
  • Subscribers 168
  • Views 9381
Sagetech
Sagetech over 1 year ago
Trying to configure differential pair spacing from pair to pair and other traces.
I've been following the Parallel Systems Differential Pair tutorial but I'm not getting the results I need.
I have my diff pair trace width and spacing set up in the physical cset.
I set up a spacing cset and net class to get my pair to pair spacing constrained. When I do this, the pairs do seem to adhere to the pair to pair spacing constraint but I get a DRC on the differential pair line to line spacing set in the physical constraint. If I remove the spacing cset, the pair spacing DRC goes away but the pair to pair spacing is no longer constrained and I can route one pair too close to the next pair.
Been through the instructions a dozen times with the same result. Instructions were published in 2020, maybe things have changed since then?
Thoughts / suggestions?
Tom
  • Sagetech
    Sagetech over 1 year ago in reply to avant +2
    So if I have 50 differential pairs I need to assign a different "class" name to each - seems time consuming.......... I'm sure I don't understand all of the groups and class assignments and method…
  • steve
    steve over 1 year ago in reply to Sagetech +2 suggested
    You need to read the supplemental notes app (under the diff pairs one) on the same website and that gives you all you need to know about why you really should set tolerances and min line spacing.
  • Sagetech
    Sagetech over 1 year ago +1
    PS: Running latest version of PCB Editor 24.1
  • excellon1
    0 excellon1 over 1 year ago in reply to Sagetech
    Hi Tom,
    So very good to hear that spacing rule worked to keep the cline away. To handle routing to the connector you could change the line to pin spacing on the custom spacing rule, if the design can stand it.
    I think another method is what Avant had suggested and that is to use a constraint region rule for the connector. This is probably the most elegant way to do it.
    So under Spacing create a new custom rule, lets call it "Connector_Spacing" Fill out the spacing as needed. In the pcb editor draw a shape around the connector.  Shape > Constraint Region Top > in the box "Assign to region" type in a name, Lets say Conn-Keepout
    and lastly draw the shape box around your connector.
    Bank in the CM Spacing Tab choose Region All Layers, on the right pane change the "Referenced CSet to "Connector_Spacing".
    Now you will have a rule that just applies to a region. You should be able to route your dp pair into that region and not have any DRC's.
    Generally speaking the spacing rules are not to bad to handle. I like to give the rules a meaningful name so as not to get lost :).
    If at all possible, I like to keep things as simple as possible for custom rules. It can be ECO Hell if alot of rules exist and you have to
    make large changes to the board.
    I think posting pics is blocked, I cant post either.
    Best Regards.
  • Sagetech
    0 Sagetech over 1 year ago
    Thank you all for the very helpful suggestions. Your tips along with some support from EMA/EDA has me headed in the right direction.
    We typically don't do many designs with diff pairs, mostly low speed digital, higher current power and RF. For past designs that have had a couple diff pairs, I set up some basic design rules and then adjust my routing grid to get the spacing I needed between them - again, simple design with two diff pairs and easy to control this way.
    The recent design I'm dioing requires multiple diff pairs on a fairly dense board so I figured this would be a good time to apply the tools available to keep the routing in check. I didn't think it would turn into such a learning curve but I believe I've got a handle on things now. I'm still a little unsure about the interaction / hiearchy of all of the "csets" but that'll come with use.
    Tom
  • excellon1
    Hi Tom
    That's good you are headed in the right direction. I'm sure your design will work out fine. On the Diff Pairs, there is some depth to getting these setup.
    When time permits, maybe work through some of the examples that was in that PS Design Note. There is much good stuff in there.
    Putting all the gobbly gook aside for a moment. One thing to be aware of is what is driving the numbers. It is the "Stackup". It would be valuable to know how your MFR will build that board in-advance so your math comes out close to expectations. If the stackup is wildly off within the tool then results for the board wont be optimal in particular if dealing with any type of impedance control. "Chicken-Egg" type of situation here.
    Chime back in if you have any additional questions.
    Best Regards.
