  3. OrCAD Capture X 25.1 Professional Stuck on "Initializing...
  • Replies 9
  • Views 5399
OrCAD Capture X 25.1 Professional Stuck on "Initializing MPS"
Ben Bina
Ben Bina over 1 year ago
After updating to 25.1 in Allegro, the search view always remains open after restart no matter how many time i close it. It always after a restart reappear again.
OrCad also in startup get stuck on "Initializing MPS" for 1-2 minute
  • Jeet
    0 Jeet over 1 year ago
    On which operations are you seeing Initializing MPS in OrCAD X Capture ?
  • Ben Bina
    0 Ben Bina over 1 year ago in reply to Jeet
    Hi Jeet
    After a reboot that problem solved. I still have the "in Allegro, the "search view/pane" always opens no matter how many time i close it,"
  • Jeet
    0 Jeet over 1 year ago in reply to Ben Bina
    Glad, the problem solved of OrCAD X Capture.
    In Allegro Can you try View > UI Settings > Reset UI to default ?
  • Ben Bina
    Reset the UI. Closed the search, open allegro again. Still the search is there.. All other pane go away if I close but search stays after restart
  • Jeet
    Can you share a screenshot of search which you are referring ?
