  3. Remove overlapping vias
  • State Verified Answer
  • Replies 8
  • Subscribers 167
  • Views 5174
bdc66a938f164d
bdc66a938f164d over 1 year ago
I have an RF design and I am using the "Place/Via Array" tool. In some parts it is doing this:
When I click on "DRC/Update" it does not even mark them as an issue. I have these settings:
When I run the `dbdoctor` command, nothing happens. I guess because it is not even considering this as a DRC.
How can I remove the overlapping vias or at least show a DRC where they occur?
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago +1
    Hello you try like this. Turn on SameNetSpacing, then move the via array by picking point (ix 0, 0) and then (0, 0). Best regards, HoangKhoi
  • bdc66a938f164d
    bdc66a938f164d over 1 year ago +1 verified
    Answering my own question: Go to `Setup/Constraints/Modes/Same Net Spacing` and then enable all.
  • John T
    John T 11 months ago in reply to Robert Finley +1 verified
    Hello all, it looks like you could do with a check for such mistakes... never fear, I got you covered! So there is a check for duplicate overlapping vias in the form of duplicate drill hole checks. …
  • John T
    +1 John T 11 months ago in reply to Robert Finley
    I just retested this here to be sure.
    Please open the Analysis Modes form and in General checks you find it as shown below;
    On a demo design I snapped two through-hole gnd vias in an overlap scenario shown below.
    Please note you will make the DRC flag visible using the "through" drc category.
    Hope this helps!
  • zpofrp
    0 zpofrp 7 months ago in reply to Robert Finley
    I try davide's skill file,it cant find the dupplicated vias, i use allegro 22,so i use the il file. cxt file maybe is 32bit, it is not work.
  • zpofrp
    0 zpofrp 7 months ago in reply to zpofrp
    sorry, this kill is OK, the skill is two blogs, it is not work in other blog.
