  3. Cmgr configuration for NPT to via hole distance
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 2027
bdc66a938f164d
bdc66a938f164d 11 months ago
I want the DRC to flag when this red distance is below some value:
Is this possible?
  • JCTEYSSIER0
    0 JCTEYSSIER0 11 months ago
    Well, canot see anything: your image have been replaced by "imgbb.cpm upgrade to a Pro account to embed images in emails"
    Can you describe the distance you want to check?
  • steve
    0 steve 11 months ago
    Yes - use the Manufacturing tab and look at Design For Fabrication - Copper Spacing. There is an option to drive a rule from a Non Plated Hole to different objects. If you have an Allegro X Venture license this has much more configuration for type of non plated hole to object type (like via). If you don't then the options are more limited but should still give you a DRC (you'll just get more DRC's).
