  3. creating new PCB layout as new canvas
  • Replies 8
  • Subscribers 166
  • Views 1818
YV202508175258
YV202508175258 6 months ago
Hello, In Altium we just create new PCB file no matter what is the schematics.
As you can see in the photos in the link(upload photos not working)
When I try to create PCB layout file its giving me a error that I have a problem with the schematics.
I dont care about the schematics I want to have PCB clean canvas and directly input footprints into it whithout schematics..
Is there a way to do it in allegro?
https://ibb.co/sdzW7x3w
https://ibb.co/SDLSgdLd
https://ibb.co/mCK4vbR4
  • excellon1
    0 excellon1 6 months ago
    Start the PCB editor from the start menu or PCB editor Icon. When the PCB Editor starts by default it creates a canvas. Provided the paths to your PCB symbols are setup, you will be able to place these elements on the canvas. You can also save that by using file save as. It will have a .brd extension.
    Be aware, the Orcad/Allegro pcb editor is "netlist" driven so a schematic is needed to create a viable board. Some pcb editors allow you to place footprints and then wire them up. When they are wired up the connections you make basically create a netlist on a pin to pin basis. Allegro does not work this way. You need to have a schematic.
    Best regards.
  • YV202508175258
    0 YV202508175258 6 months ago in reply to excellon1
    Hello excello1, I only have PCB editor viewer.although I have a full proffesional license
    two questions:
     1. I also have orcad x pcb presto is it a good alternative?
    2. is there another way to get the pcb editor?
    Thanks.
  • excellon1
    0 excellon1 6 months ago in reply to YV202508175258
    It seems odd that you have the PCB Viewer but cant seem to access the full pcb editor, Suggest you do a re-install. When you install the product, install it with all options and for all users on the PC.
    The Orcad Pro version is a very good tool, suggest you just go with that since you have a license for it.
    Best regards.
  • JCTEYSSIER0
    0 JCTEYSSIER0 6 months ago in reply to excellon1
    itc is possible to use a netlist written with a text editor but it is not easy. Prefer the schematic way. SInce you have a Orcad Pro licence, use Orcad Capture as shematic editor
  • YV202508175258
    0 YV202508175258 6 months ago in reply to JCTEYSSIER0
    Hello, but I dont use a schematics I have random object like rectangle on the top layer   I just want to assigh a net name to it.
    Is there some example that could help me?
    Thanks.
