  3. creating new PCB layout as new canvas
  • Replies 8
  • Subscribers 166
  • Views 1819
YV202508175258
YV202508175258 6 months ago
Hello, In Altium we just create new PCB file no matter what is the schematics.
As you can see in the photos in the link(upload photos not working)
When I try to create PCB layout file its giving me a error that I have a problem with the schematics.
I dont care about the schematics I want to have PCB clean canvas and directly input footprints into it whithout schematics..
Is there a way to do it in allegro?
https://ibb.co/sdzW7x3w
https://ibb.co/SDLSgdLd
https://ibb.co/mCK4vbR4
  • JCTEYSSIER0
    0 JCTEYSSIER0 6 months ago in reply to YV202508175258
    Never used  but maybe have a look to Logic->Net Logic
  • JCTEYSSIER0
    0 JCTEYSSIER0 6 months ago in reply to JCTEYSSIER0
    Alternative is using telsis format: use a google (or your prefred search engine) with "allegro telesis netlist" you will find exemples
  • excellon1
    0 excellon1 6 months ago in reply to YV202508175258
    Hi Again.
    If you have access to the Allegro Full tier product you can use net logic to populate the database with Net names so as to derive connectivity between things like shapes.
    This option is not available on the Orcad products.
    While its possible to create a manual netlist there is a proviso. You have to have a component, for example a resistor. This is because the pins on components are used for the net information. Your also going to need a physical PCB footprint too.
    The component will also need a ref dez, like R1 etc. If I am not mistaken you also will need a device file for each pcb footprint
    if doing a text based netlist.
    Its not possible to create a netlist without these items defined first because the Netlister will fail !.
    The best option is to create a small schematic using Orcad Capture first.
    If the board is really simple say just square pads and there are not too many, you could draw them in using shapes in the pcb editor and not worry about any netlist at all.
    Best regards.
