  3. count via by net and layer to csv file
  • Views 1257
zpofrp
zpofrp 6 months ago
there is a report in allegro.But this report is not intuitive.  I want to show via num by net and layer in a csv. for example
Net name, L1 Total Vias, Drill_L1L2 total Vias, L2 Total vias,Drill_L2L3 total vias, ..........Base
GPIO2,1,1,1,1,.......1
VSS,2000,2000,3500,3500,......1000
I can easily find out which layer the via is too few. Currently, I have implemented report generation using Skill Replay Report. But,I am unable to convert the report into the CSV format, as shown above.
  • zpofrp
    zpofrp 6 months ago
    no, this report isnot power and ground.
    Report Features:
    1. The report displays only vias connected to a net. Other vias can be located using "Dangling Line, Via and Antenna Report".
    2. Vias with VOLTAGE/RATSNETS_SCHEDULE property with value of POWER_AND_GROUND are excluded from the report.
    so,  i cant use scripts and replay.
  • Hoangkhoipcb
    Hoangkhoipcb 6 months ago
    Hi Zpofrp, could you share your skill file with me via email?
