  3. After converting a PADS ASCII PCB using Allegro PCB Editor...
  • Views 1736
After converting a PADS ASCII PCB using Allegro PCB Editor 25.1, component information such as reference designators will be lost, and the Options Dialog will not pop up during the conversion process.
Zhifeng Jin
Zhifeng Jin 6 months ago
Recently, I need to convert a PADS PCB design file into Allegro PCB Editor 25.1. I have tried many times and found that all component information is lost after conversion, including reference designators, component values, and some individual nets.
In addition, during the conversion process, the Options Dialog that used to pop up in Allegro 16.6 never appears in the new 25.1 version. I frequently performed PADS PCB to Allegro PCB conversions in 16.6 before and never encountered such issues.
Has anyone run into the same problem?
BTW, after the PCB conversion is completed, all component reference designators in the PCB have turned into #REFDES.
  • SaiPavanl
    0 SaiPavanl 6 months ago
    Hello  Zhifeng Jin, In the “PADS In” dialog, there is an option called “Show Options Dialog.” Have you checked this option?
  • Zhifeng Jin
    0 Zhifeng Jin 6 months ago in reply to SaiPavanl
    Yes, I have this option checked here, and I’m aware of this setting. The Option dialog box pops up normally in versions 16.6, 17.2 and 17.4. However, it does not appear in version 25.1 even when this option is enabled. You may try testing this behavior in 25.1 yourself.
  • Zhifeng Jin
    0 Zhifeng Jin 4 months ago in reply to SaiPavanl
    Hi SaiPavanl,I have found a solution to the problem where all reference designators display as #REFDES. However, the Show Options dialog fails to pop up consistently in version 25.1, which prevents us from configuring the relevant conversion options,
    Do you know why the Show Options dialog box fails to pop up in version 25.1?
    If this is an issue, can anyone assist with submitting a CCR? Thank you!
  • SaiPavanl
    0 SaiPavanl 4 months ago in reply to Zhifeng Jin
    Hello  Zhifeng Jin, A CCR has been already submitted regarding this issue.
  • Zhifeng Jin
    Much appreciated.
