  3. Is there any check available in Allegro to catch the impedance...
  • State Suggested Answer
  • Answers 1
  • Views 742
Is there any check available in Allegro to catch the impedance traces running parallel on adjacent layers?
BC202603263145
BC202603263145 6 months ago
I have a 6-layer stackup with differential pairs routed on L4 and L5. Since the board density is high, I want to avoid having these traces run parallel to each other across these layers.
Is there a check available in Allegro to detect such parallel routing violations?
Thanks!
  • JuanCR
    0 JuanCR 6 months ago
    I think what you want you can achieve with the DRC MAX_PARALLEL. You find it in Constraint Manager > Electrical Constraints > Routing > Wiring > Max Parallel
