  3. Field Solver Selection in Allegro (BEM2D vs EMS2D)
  • State Suggested Answer
  • Answers 1
  • Views 1680
Electro Node
Electro Node 6 months ago
Hi everyone,
From the Cadence documentation, it appears that the EMS2D field solver is recommended for designs operating above 2.5 GHz for various calculation in tool.
In my case, the design frequency is greater than 2.5 GHz, but I still observe that Allegro is using the BEM2D field solver.
I wanted to understand that from where in the tool can we select or switch between BEM2D and EMS2D?
I Would appreciate any guidance or insights on this.
  • excellon1
    0 excellon1 6 months ago
    Hi Electro
    The solvers are somewhat low level options that perform calculations. In Allegro and I believe it depends on the license options, these are associated typically with the signal analysis module - Sigwave. Within in sigwave you can specify the solver to use.
    There are alot of moving parts associated with this. A good resource is available here.
    https://www.parallel-systems.co.uk/images/PDF/sigxpug.pdf
    Best regards.
  • Electro Node
    0 Electro Node 6 months ago
    Hi folks,
    Any insights on this?
  • John T
    0 John T 6 months ago in reply to Electro Node
    Hi Electro Node, just wanted to give you some official feedback on this. Please be aware that EMS2D functionality is exclusive to Allegro X PCB SI licenses only and cannot be accessed via OrCAD X PCB Editor standard licenses. It is selected using menu the menu Analyze > Preferences > Interconnect Models,then select the desired solver under the Trace Solver option. Some reference documentation: Working with Allegro PCB SI Field Solvers - EMS2D Settings.
    Bem2D vs EMS 2D :The Electromagnetic Solution 2D Full Wave field solver-EMS2D-in PCB SI and SigXplorer provides the full-frequency range analyis from DC, through the middle frequency range which covers the skin effect, to the THz range of the electromagnetic interactions which address resonances, radiations and EM signal integrity issues. EMS2D is implemented using the finite element method (FEM), which complements Allegro's moment-based BEM2D field solver. EMS2D combines multiple EM computation modules, static, quasi-TEM, and full-wave analysis. Additionally, EMS2D is able to analyze arbitrary transmission line-type and waveguide structures over PCB cross-sections and provide characterized models in RLGC and/or S-Parameter format
  • Electro Node
    Hi excellon1,
    Thank you for the clarification and for sharing the reference document.
    You are absolutely right  the field solver selection is closely related to the available license options and the Signal Analysis/SigWave capabilities within Allegro. Following the guidance shared earlier by John T, I was able to successfully switch between the BEM2D and EMS2D solvers and explore them based on my design requirements.
    I also found the latest Allegro SI documentation from the Cadence website extremely helpful in understanding the solver behavior and configuration options in more detail. It is great to see the level of flexibility Allegro provides for high-speed design analysis.
    Hi John T ,
    Thankyou so much for your kind support. Really appreciate your time and support in pointing me in the right direction.
    Thanks again!
