  3. What is Preventing Designers from Improving Decoupling?
  • Replies 7
  • Subscribers 166
  • Views 1192
John T
John T 3 months ago
We see many designs every day but most do not follow the performance recommendations when it comes to power and ground via placement for decoupling capacitors.
Why ?
What is preventing you from pushing your designs to perform at their electrical best:
1. Is it costs?
2. Is it due to manufacturing or fabrication?
3. Is it speed for design completion or DRC management?
The highest level recommendation is to place grounding and power vias inside the capacitor pads
Let’s share some industry experience if anyone has overcome these hurdles or have suggestions or reasons for the approach.
Appreciating any thoughts or comments below.
  • avant
    avant 2 months ago +2
    We don't use via-in-pad. We produce 1M+ units a year. Expense and manufacturing issues outweigh benefit for us. We typically use #2 with vias tied to planes, and wide traces. We use a lot of 0201…
  • excellon1
    excellon1 3 months ago +1
    Hi John, Good topic. The caps look too big for the pads :), probably just to illustrate I'm sure. So Level 3 works very well, I have used this fairly regularly as I do RF based layouts into the GHz.…
  • avant
    avant 2 months ago in reply to John T +1
    Hi John, I should have clarified - Our designs are usually single-sided with only optional memory and related components on the back side. Decoupling caps for the top side components are on the top…
  • John T
    John T 2 months ago in reply to avant
    Sometimes it makes you wonder if it would be possible to embed just the ground pad on the lower layer, soldering directly to the inner ground plane...For thin dielectric layers the thickness difference might not be so bad to enable soldering potentially. The technology is already there for making punch openings in the prepreg, or just micro-milling. Hope my meaning is clear.
  • CC202608287943
    CC202608287943 2 months ago in reply to excellon1
    Thanks for the detailed explanation. I’m still fairly new to PCB layout, so some of this is new to me, but the point about keeping the trace width closer to the pin width makes sense. I’ll keep the via placement and inductance in mind as well.
