  3. Change Connect Pin to Mechanical
  • Replies 11
  • Views 28372
archive over 18 years ago
Other than deleting a Connect pin and inserting a Mechanical pin in it's place, is there a method of changing a Connect pin to Mechanical ?
Originally posted in cdnusers.org by dschaefer
  • arehnman
    arehnman over 14 years ago +2
    Actually it's very simple but I have to admit it's not very intuitive (at least until you know how to do it) To change a connect pin to mechanical pin 1) Click delete icon 2) Select text in object find…
    Just change your find filter so Text is checked, delete the pin number text and you are good to go. Of course this can only be done inside of the Allegro symbol (.dra) and not the layout (.brd).
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
    Hey there,
    What about the other way around? Changing a mechanical pin to a connect pin?
    Jackie
    Originally posted in cdnusers.org by Jackie
    It's better to replace the mechanical pin to a connect pin inside symble (.dra) using "Add pin" option.
    Originally posted in cdnusers.org by shiva
    Jackie,
    There is a way to convert a mechanical pin to a connect pin but it should only be used when you have multiple(many) pins to convert and it would take too long to replace them manually using "Add Pin".
    All you need to do is to create a sub-drawing (File > Export > Sub-Drawing) of just the pins using x 0 0 as your origin point then manually update the sub-drawing file (.clp) file by globally replacing the following string: (add 99 as your pin number)
    -->From
    _clpInitPinText(_clp_pin_text "" 0:0)
    -->To
    _clpInitPinText(_clp_pin_text "99" 0:0)
    Once you make these change you can deleted the existing mechanical pins and import the modified sub-drawing (File > Import > Sub-Drawing) into your symbol using x 0 0 as your insertion point. Now the pins will have an pin number associated to them which makes them a connect pin and using Edit > Text you can change the pin number place holder 99 to the correct pin number.
    Doing it this way you don't have to stress on placing the new connect pins at the exact same location as the existing mechanical pins and all you need to do is update the attached pin numbers.
    Like I said before if you only have a couple mechanical pins to convert to connect pins then it would be fast to just replace them using "Add Pin" as Shiva indicated but if you have lots of mechanical pins to convert it is just faster going the sub-drawing Export/Import route.
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
    Mike,
    Thanks for the replies. Would have hoped that there would be better support within Allegro for converting between Mechanical and Connect pins. I guess not something most do too often if libraries were created from scratch in Allegro, but for those of us transitioning and converting libraries from other tools such as OrCad Layout it would really help.
