  3. axlPolyFromDB, "line" objects and 15.x
  • Subscribers 163
  • Views 6388
archive over 19 years ago
Greetings,
The documentation states that axlPolyFromDB will work with "path", "line" and "arc" objects, amongst others.
Under 15.2 I can successfully obtain a poly from a cline/"path" object BUT cannot obtain a poly from a clineseg/"line" object.
Try the following:
capture a CLINE, name it cline_db
capture a CLINESEG from CLINE, name it clineseg_db
cline_poly = car( axlPolyFromDB( cline_db))  ; works for me
clineseg_poly = car( axlPolyFromDB( clineseg_db)) ; does NOT work for me
Can anyone verify this behavior?
I'm whipping up a report that will detect etch that gets too close to pins.
Thanks and have a great Friday,
Chris Walters
local Cadence guru
PS - anyone know of a position for a(nother) Cadence guru?
Originally posted in cdnusers.org by kerchunk
    Works OK in 16.0. I vaguely remember problems in 15.2 that I raised several SRs for. Have you got the latest ISR?
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    I've confirmed this behavior on an associates' box - axlPolyFromDB does not work under 15.2 for "line" or "arc" dbids but does work under 15.7 .
    Thx to all who responded.
    Chris Walters
    local Cadence guru
