  3. about lines startend points
  • Replies 17
  • Subscribers 18
  • Views 18008
tennywhy
tennywhy over 8 years ago
i want get all lines start and end points on outline layer, there is the code
defun( apl ()
    let( (RLP symbPg symbPth allSymbols allSymbolss)
    ;print all lines startend point
    axlSetFindFilter(?enabled list("noall" "lines")
        ?onButtons list("noall" "lines"))
    allSymbols = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    foreach( everyLine allSymbols
            axlMsgPut("startis %L" everyLine->startEnd) ; it doesnt work
            ;axlMsgPut("startis %L" everyLine->?) ;checked it has startEnd properties
            ;axlMsgPut("startis %L" everyLine->??) ;checked it has startEnd properties
what's the right way ?  and in the skill UG there is a starEnd attribute as in image below. how could i do it ?
  • DE202408202727
    DE202408202727 over 8 years ago
    startEnd is and attribute of a line segment - not the symbol itself.
    use something like
    foreach(symbol, allSymbols
      foreach(pathObj setof(obj, symbol ->children, obj ->objType == "path")
        foreach(segment, pathObj, ends = segment ->startEnd
  • tennywhy
    tennywhy over 8 years ago in reply to DE202408202727
    hi dave very appreciate your reply.  i tried it ,  it cant work. it's seem as there is no children attibutes, and there is no children attibutes in line attributes shown in the image above.
    i tried other attributes in the line attributes table also , cant get work still.  could you give me some moer advice please ? i have stucked here several days
  • DE202408202727
    DE202408202727 over 8 years ago in reply to tennywhy
    Post your code here. I can't help if I don't know what you are doing.
  • tennywhy
    axlCmdRegister( "autoPlace" 'autoPlace)
    defun( autoPlace ()
        axlSetFindFilter(?enabled list("noall" "Lines")
            ?onButtons list("noall" "Lines"))
        axlClearSelSet()
             ;printf("symbol is %L" symbol) ;can be get right dbid at here
                 ;printf("pathObj is %L" pathObj) ;nothing at here
                 ;printf("ends is %s" ends) ;nothing at here
    1) this is my code , my purpose is get all lines at visible layer , and list all line segments start and end point.
    2) i have tested the symbol attributes use symbol->?? it seem as not children attributes
    3) it seem as symbol->? also displayed some attributes, what different  ->? and ->?? ,  if ->? dispalyed attributes can not be refernce directely ?
  • DE202408202727
    You set your find filter to "lines" and then expect to get symbols returned!
