  3. about lines startend points
  • Replies 17
  • Subscribers 20
  • Views 17605
tennywhy
tennywhy over 8 years ago
i want get all lines start and end points on outline layer, there is the code
defun( apl ()
    let( (RLP symbPg symbPth allSymbols allSymbolss)
    ;print all lines startend point
    axlSetFindFilter(?enabled list("noall" "lines")
        ?onButtons list("noall" "lines"))
    allSymbols = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    foreach( everyLine allSymbols
            axlMsgPut("startis %L" everyLine->startEnd) ; it doesnt work
            ;axlMsgPut("startis %L" everyLine->?) ;checked it has startEnd properties
            ;axlMsgPut("startis %L" everyLine->??) ;checked it has startEnd properties
what's the right way ?  and in the skill UG there is a starEnd attribute as in image below. how could i do it ?
  • tennywhy
    tennywhy over 8 years ago in reply to eDave
    oh, im sorry. for test your code post above, i think it's not a keywords, im not change it. i changed the symbol and allSymbol to myLines & allLines and test it just now, it's the same result. the code as below
    axlCmdRegister( "autoPlace" 'autoPlace)
    defun( autoPlace ()
        let( (RLP symbPg symbPth myLines allLines)
        axlSetFindFilter(?enabled list("noall" "Lines")
            ?onButtons list("noall" "Lines"))
        allLines = axlGetSelSet(axlAddSelectAll())
        axlClearSelSet()
        foreach(myLines, allLines
             ;printf("lines is %L" myLines) ;can be get right dbid at here
             foreach(pathObj setof(obj, myLines ->children, obj ->objType == "path")
                 ;printf("pathObj is %L" pathObj) ;nothing at here
                 foreach(segment, pathObj, ends = segment ->startEnd
                 ;printf("ends is %s" ends) ;nothing at here
    1) this is my code , my purpose is get all lines at visible layer , and list all line segments start and end point.
    2) i have tested the symbol attributes use symbol->?? it seem as not children attributes
    3) it seem as symbol->? also displayed some attributes, what different  ->? and ->?? ,  if ->? dispalyed attributes can not be refernce directely ?
    please give me a guide, im very very appreciated that.
  • eDave
    eDave over 8 years ago in reply to tennywhy
    Just as confused. A path is a child of a symbol.
  • tennywhy
    i cant understand your means actually, how can i solve this problem? could you explain it to me more detail?
  • eDave
    Maybe this will help you:
    defun( autoPlace ()
    let((allLines, ends)
    axlSetFindFilter(?enabled list("noall" "Lines") ?onButtons list("noall" "Lines"))
    axlClearSelSet()
    foreach(line, allLines
    foreach(segment, line ->segments
    printf("ends is %s\n" ends)
  • eDave
    eDave over 8 years ago in reply to eDave
    The printf statement should be printf("ends is %L\n" ends)
