  3. about lines startend points
  • Replies 17
  • Subscribers 20
  • Views 17615
tennywhy
tennywhy over 8 years ago
i want get all lines start and end points on outline layer, there is the code
defun( apl ()
    let( (RLP symbPg symbPth allSymbols allSymbolss)
    ;print all lines startend point
    axlSetFindFilter(?enabled list("noall" "lines")
        ?onButtons list("noall" "lines"))
    allSymbols = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    foreach( everyLine allSymbols
            axlMsgPut("startis %L" everyLine->startEnd) ; it doesnt work
            ;axlMsgPut("startis %L" everyLine->?) ;checked it has startEnd properties
            ;axlMsgPut("startis %L" everyLine->??) ;checked it has startEnd properties
what's the right way ?  and in the skill UG there is a starEnd attribute as in image below. how could i do it ?
  • tennywhy
    tennywhy over 8 years ago in reply to eDave
    its get work, thank you very much Dave.  i have two question reserved.
    one; how do you kown it has a segments attributions, i check the skill UG, it just as the image i post above there arent a segments attributions in the list, where can find the explain about this?
    two: what's the different between  ->? and ->??   ?
  • eDave
    eDave over 8 years ago in reply to tennywhy
    1. Refer to the Allegro Skill Reference (algroskill.pdf) Path Attributes.
    2. ->? returns a list of the names. ->?? returns the list of names and values (much more useful usually)
  • Jason Hsu
    Jason Hsu over 7 years ago in reply to eDave
    Hi Dave,
      Do you know how to get the width for path? I want to know the width of lines on "PACKAGE GEOMETRY/ASSEMBLY_TOP". But the line's objType is path. you know only line has width attribute, how could I get the information for path? Please give me your suggestion. Thanks in advance.
  • Jason Hsu
    It seems I can get the width by car(myline->segments) ->width, is it correct? Or it is detour way?
  • eDave
    eDave over 7 years ago in reply to Jason Hsu
    axlPathGetWidth or axlPathSegGetWidth
