  3. about lines startend points
  • Replies 17
  • Subscribers 20
  • Views 17620
tennywhy
tennywhy over 8 years ago
i want get all lines start and end points on outline layer, there is the code
defun( apl ()
    let( (RLP symbPg symbPth allSymbols allSymbolss)
    ;print all lines startend point
    axlSetFindFilter(?enabled list("noall" "lines")
        ?onButtons list("noall" "lines"))
    allSymbols = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    foreach( everyLine allSymbols
            axlMsgPut("startis %L" everyLine->startEnd) ; it doesnt work
            ;axlMsgPut("startis %L" everyLine->?) ;checked it has startEnd properties
            ;axlMsgPut("startis %L" everyLine->??) ;checked it has startEnd properties
what's the right way ?  and in the skill UG there is a starEnd attribute as in image below. how could i do it ?
  • Jason Hsu
    Jason Hsu over 7 years ago in reply to eDave
    Dave,
      axlPathGetWidth or axlPathSegGetWidth require a r_path parameter, it means _axlPath@. But here, I can get many lines(path) from an existing layer. It will be dbid: -number format. It seems I can't use axlPathGetWidth or axlPathSegGetWidth to get the width's information directly. Any other idea from you? Or I have to use car( myline ->segments) ->width? Thanks for your help.
  • eDave
    eDave over 7 years ago in reply to Jason Hsu
    Just get the width attribute of the line segments. If your line dbid is lineDBID then car(lineDBID ->segments) ->width will give you a value
