  3. Suppress Errors While Automatically Exporting Padstack with...
  • Subscribers 18
  • Views 11384
Suppress Errors While Automatically Exporting Padstack with Shape
EMperson
EMperson over 8 years ago
Hi all,
     I wrote a program that automatically exports padstacks. It starts by opening allegro with the symbol, then opens each padstack in the padstack editor. The code I use in the padstack editor looks like this:
QtSignal MainWindow ExportXml triggered
QtFillin Blah.pxml
QtFillin Save
QtSignal MainWindow Exit triggered
However, if the padstack has a shape with an offset, an error message box pops up saying "Origin is outside or on pad edge for layer TOP, REGULAR-PAD. Changing offset to set origin at pad center".
Is there a way to automatically exit this message, or suppress, or ignore it? I don't want the users of my program to have to click the message box, and export the padstack themselves.
Some example code, example functions, or links to information would be very helpful :)
  • DE202408202727
    DE202408202727 over 8 years ago
    Why not use axlPadstackToDisk?
    I avoid using scripts whenever possible as they can change between releases or hang as you have seen.
  • DE202408202727
    If you must use a script CPT_OFF_PAD may be the variable you need to investigate
  • EMperson
    EMperson over 8 years ago in reply to DE202408202727
    I want the information from the padstack. Like, padstackname and all the information from both design layers, and mask layers-- width, height, figure...
    If I export a padstack to xml I can get that info.
    If I used axlPadstackToDisk to export the padstack itself,  what function should I use to get the information I want?
    Thanks!
  • DE202408202727
    DE202408202727 over 8 years ago in reply to EMperson
    eg:
    psid = axlLoadPadstack(padstackName)
    pad = axlDBGetPad(psid, layer, "REGULAR")
    pad ->??
  • EMperson
    This link has information that does exactly what I want: https://community.cadence.com/cadence_technology_forums/f/pcb-design/24786/extracta-and-pad-files
    There is code in the link to export all information from a .pad file to a .txt file
