  3. How do I get a pad geometry?
  • Subscribers 18
  • Views 10189
HJerry
HJerry over 7 years ago
Hi all,
I need to check if a pin padstack has the geometry "oblong" by the pin dbid. Is there a short cut to do this?
These are surface mount pins.
Jerry
  • DE202408202727
    DE202408202727 over 7 years ago
    axlDBGetPad(pinDBID, "TOP", "REGULAR") ->figureName
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    Onice you have the pin dbid, get the pad data for the TOP layer, which contains the pad figure shape info, then check that for OBLONG_X or OBLONG_Y
    Skill > pin=car(axlGetSelSet())
    Loading signal.cxt
    dbid:36668pad1592
    Skill > pad=axlDBGetPad( pin "ETCH/TOP" "regular")
    pad:315170864
    Skill > printf( "Pad figure type : %s\n", pad->figureName)
    Pad figure type : OBLONG_X
    t
    Skill >
