  3. Allegro script runs fine in the SKILL interpreter window...
  • Subscribers 20
  • Views 12233
Allegro script runs fine in the SKILL interpreter window, fails when running from the Allegro Command line
David M Gonzales
David M Gonzales over 6 years ago
This is a small piece of my SKILL script. It simply replays an Allegro script
axlCmdRegister("mcadsoldermask" 'MCADsoldermask ?cmdType "interactive" )
procedure( MCADsoldermask()
axlShell( "replay ./ReplacePadstack.scr" )
);procedure
Below is the Allegro script that is called
version 17.2
setwindow pcb
trapsize 3095
replace padstack
setwindow form.mini
FORM mini oldname NPIN1929
FORM mini newname NPIN1929_SMASK
FORM mini replace
setwindow pcb
prepopup rel 0.0000 0.0000
done
When I run the script in the SKILL interpreter window, it works fine. Replace Padstack updates the padstacks.
When I run the script from the Allegro Command Line, it fails.
It executes the Replace Padstack command fine
When it calls "FORM mini oldname NPIN1929" I get the error message "Form field label not found"
Can anyone please help me?
  • fSeyer
    fSeyer over 6 years ago
    try to use axlreplacepadstack
  • joma
    joma over 6 years ago
    You could try changing ?cmdType from "interactive" to "general".
    Jim O'Mahony
  • David M Gonzales
    David M Gonzales over 6 years ago in reply to joma
    Thanks Jim, That's it!
    I'm a SKILL newbie. I read the documentation for axlCmdRegister and am confused about interactive vs. general usage.
    Could you please explain for me?
  • joma
    joma over 6 years ago in reply to David M Gonzales
    The ?cmdType "interactive" is usually better for programs that expect input from the user. Most other cases
    work better with ?cmdType "general".
