  3. Making skill form and logic for IDX transfer.
  • Subscribers 20
  • Views 11022
Mhawley1
Mhawley1 over 5 years ago
Hey Everybody , I am working with the IDX MCADECAD collaboration and I have finally given up using it . In the end this tool is completely unacceptable for use with Siemens NX . Reasons being there is poor recognition on when files are read and accepted back and forth and the units that Siemens use is in inches which allegro then treats as mils .
The only way I see to remedy this is to rebuild the form in allegro and build in custom logic . The problem I have is that I cant find a skill routine that allows for immediate IDX import and export . Its kind of funny because if you type in skill idx it completes like there is some functions there .
what I want as a skill function is IDX_IN <argument with file path> but it doesnt exist . Can anybody dig something up on this and or test it so see if it works.
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    the IDF & IDX import/export are individual programs that are called from Allegro, so I do not think there is any existing skill code available...
  • Mhawley1
    Mhawley1 over 5 years ago in reply to DavidJHutchins
    It looks like your correct sir , The good news is I did find some sort of command in the help documents . I didn't get it to work but least its something .
    Other interesting discoveries including finding the IDX_IN.exe in C:\Cadence\SPB_17.4\tools\bin . Either way it seems like i'm trying to do something that is not implemented yet .
  • RFinley
    RFinley over 5 years ago
    I like Unigraphics/NX.
    But, the shortest path to using IDX is to deploy SolidWorks because of EMA's CADSync SolidWorks/Allegro plugin.
    https://youtu.be/8kD1BOMo-B0
  • Mhawley1
    Mhawley1 over 5 years ago in reply to RFinley
    Thank you for the video , it shows how the software is supposed to work . I think what I am  going to do is put in a background process that modified the IDX files at some refresh rate . Really the only files that dont work right are the incremental changes exported from NX. All the units need to be moved 3 decimal places . The other issue is NX keeps making a new IDX file at each increment and Allegro continues to use the oldest file . I will tackle this by destroying all old files automatically .
    As long as I can fake a solution it will work . I will report when I am done incase anyone else is trying to get this to mesh with NX .
  • RFinley
    RFinley over 5 years ago in reply to Mhawley1
    Oh, never mind.   Glad you are able to resolve the problem through updates to the IDX files.
