  3. DOES ALLEGRO FREE PHYSICAL VIEWER SUPPORT SKILL? (Ver 17...
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 21
  • Views 9523
DOES ALLEGRO FREE PHYSICAL VIEWER SUPPORT SKILL? (Ver 17.2)
Debby
Debby over 3 years ago
Hi all,
I am trying to use Skill in free viewer 17.2.
I knew Skill function is not available in free viewer normally but there was a post of a workaround by adding skill code in allegro.ilinit
https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-editor-skill/19795/does-allegro-free-physical-viewer-support-skill
However, it still failed.
Here is my code in "allegro.ilinit"
axlCmdRegister("c_layer" 'c_layer ?cmdType "interactive")
mySkillFunction.autoload = "c_layer.il"
Can anyone help on it? Thanks!
  • Debby
    0 Debby over 3 years ago in reply to DE202408202727
    Hi Dave,
    That didn't work. Do I have to set the skill path in any file?
    Also, I didn't see any file setting the path of allegro_site. I got the path of my allegro_site by cmd "set" in allegro. Is that correct?
    Furthermore, maybe there's something wrong in my skill code and leads to the failure.
    Could you provide a short skill code to try with? Thanks!
  • mfil
    0 mfil over 2 years ago in reply to Debby
    Same here.. i try to load a skill .il File on startup.
    For the Allegro PCB Designer it worked but for the Free Viewer i don't get it.
    Maybe the allegro.ilinit will be ignored from the Allegro Free Viewer.
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to mfil
    Skill will not work with the Allegro Free Viewer.
