  3. DOES ALLEGRO FREE PHYSICAL VIEWER SUPPORT SKILL? (Ver 17...
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 21
  • Views 9522
DOES ALLEGRO FREE PHYSICAL VIEWER SUPPORT SKILL? (Ver 17.2)
Debby
Debby over 3 years ago
Hi all,
I am trying to use Skill in free viewer 17.2.
I knew Skill function is not available in free viewer normally but there was a post of a workaround by adding skill code in allegro.ilinit
https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-editor-skill/19795/does-allegro-free-physical-viewer-support-skill
However, it still failed.
Here is my code in "allegro.ilinit"
axlCmdRegister("c_layer" 'c_layer ?cmdType "interactive")
mySkillFunction.autoload = "c_layer.il"
Can anyone help on it? Thanks!
  • DE202408202727
    0 DE202408202727 over 3 years ago
    That should work if everything is in the correct path.
    You probably don't need autoload. You could just use
    load("c_layer.il")
    Try including the path.
  • Debby
    0 Debby over 3 years ago in reply to DE202408202727
    Hi Dave,
    Both files ("allegro.ilinit" and "c_layer.il") are under path "C:\SPB_Data\pcbenv".
    I've modified "allegro.ilinit" as below, but still failed:
    load("c_layer.il")
    Here is the code in "c_layer.il":
    defun(c_layer (@optional (layer ""))
    );end defun
    And this is the error message in allegro:
    Command > c_layer 1
    E- Command not found: c_layer 1
    Could you tell what the problem is? Thanks!
  • DE202408202727
    0 DE202408202727 over 3 years ago in reply to Debby
    Your Skill files should be in the skill folder under the folder defined in your allegro_site variable.
  • Debby
    Hi Dave,
    My allegro_site = C:/XXX/Cadence Design Systems/17.2/share/local/pcb
    It still failed after I put "c_layer.il" under allegro_site.
    Sorry I'm a beginner of allegro. Could you guide me with more detail? Maybe an example? Thank you!
  • DE202408202727
    Hi Debby.
    No problem. We were all beginners once!
    Create folder: C:/XXX/Cadence Design Systems/17.2/share/local/pcb/skill
    Put your skill code in there. That should work.
