  3. CHECKBOX in the FORM during the while loop
  • State Verified Answer
  • Answers 1
  • Subscribers 21
  • Views 3912
JuriV
JuriV over 3 years ago
Hi everybody,
do you know how is possible to check CHECKBOX in the FORM during the while loop?
In my FORM I have two checkboxes. In the EVENT procedure (including a WHILE loop) I want implement in the PICK section:
     "Do something 1" if CHECKBOX1 in the FORM is checked
     "Do something 2" if CHECKBOX2 in the FORM is checked
In my code this not works, because the CHECKBOX in the FORM cannot not be CHECKED in the loop. The loop must be interrupted (e.g. with axlCancelOn())  to make check in the FORM.
Do you know if this works without interruption?
Hier is example:
test_form = axlFormCreate( (gensym) "test_form.form" nil 'test _action t)
(including CHECKBOX 1 and CHECKBOX 2)
procedure( test_form()
eventMask = '( PICK CANCEL DONE)
loop = t
while( loop
     event = axlEnterEvent(eventMask, nil, t)
     case(event -> type
     ('PICK
        if CHECKBOX 1 then do work 1…..
        if CHECKBOX 2 then do work 2…..
     ); end PICK
 ('CANCEL
     printf("End of Loop")
     loop=nil
 );end CANCEL
  );end while
  );end case
);end procedure
JuriV
  • JuriV
    JuriV over 3 years ago in reply to mahimag +2 verified
    I have done it with axlFormSetEventAction( form 'form_callback). Its works even during the while loop. while( eventloop event = axlEnterEvent(list('STARTDRAG 'PICK 'STOPDRAG) nil nil) .... ('STOPDRAG…
  • JuriV
    JuriV over 3 years ago in reply to John T +1
    Hi John T, thank you for the reply. Unfortunately it not works. The FORM is not activ in the loop. I need to interrupt the loop first.
  • mahimag
    mahimag over 3 years ago +1 suggested
    Hi @JuriV, to set/unset the checkbox inside while loop is as an interupting event. I tried something like while(axlFormGetField(fls "inc_summary") printf("hello")) axlFormSetField(fls "inc_summary" nil…
  • John T
    0 John T over 3 years ago
    Hi JuriV, in past forums there is a discussion regarding How to keep form window Active while running scripts:
    https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-editor-skill/17997/how-to-keep-form-window-active-while-running-scripts
    In this there is information how to retain an active form by adding axlUIWPerm(lib_form, t) after the axlFormCreate command. Could this be of use to you in this scenario?
  • JuriV
    0 JuriV over 3 years ago in reply to John T
    Hi John T,
  • mahimag
    0 mahimag over 3 years ago
    axlFormSetField(fls "inc_summary" nil)
    It did not work because, while loop needs to be interupted (or you need to come out of the while Loop) in order to change the checkbox filed value.
  • JuriV
    +1 JuriV over 3 years ago in reply to mahimag
    while( eventloop
     ('STOPDRAG
                                               when( form -> curField == "Checkbox1"
                                                              do something 1 ()
                                               ); end when
                                               when( form -> curField == "Checkbox2"
                                                              do something 2 ()
                                                 ); end when
                                            ); end while
    procedure( form_callback(form)
    printf("Checkbox is changed" )
    );end
    • Vote Up +2 Vote Down
