  3. How to choose the component which in a partition with skill...
  • State Verified Answer
  • Subscribers 23
  • Views 4583
How to choose the component which in a partition with skill code?
kobe882424
kobe882424 over 3 years ago
  • kobe882424
    kobe882424 over 3 years ago in reply to JuanCR +1 verified
    Thanks JuanCR. I got the reason and solution to the problem after reading the guideline of skill. the reason is that the pcb was completed by a team. so the list(?enable) needs to add "DYNTHEMALS"…
    0 Andrew Beckett over 3 years ago
    I don’t understand the question. Which tool are you using? What do you mean by “in a partition”?
  • kobe882424
    0 kobe882424 over 3 years ago in reply to Andrew Beckett
    thanks for your reply.
    use axlDBGetDesing to get the component,so can got it's imformation as follow:
    Skill > a~>parentGroups~>type
    (("PARTITION"))
    but it is not useful with  "axlSingleSelectBox" to choose the component (allegro 17.2). Pls help,thank.
    0 Andrew Beckett over 3 years ago in reply to kobe882424
    Ok, that explains it. This is nothing to do with Custom IC design but a PCB/Allegro question. I’ll move your post to the correct forum (please take care in future to post in the right place and provide sufficient detail when asking questions).
  • JuanCR
    0 JuanCR over 3 years ago
    Hi Kobe,
    I believe what you're looking for is something like this:
    axlSetFindFilter(?enabled '(noall shapes) ?onButtons '(noall shapes)); configures the Find filter to only allow selection of shapes.
    axlSelect(); After executing this line, you can click on the shape that you want to select
    shapeID=car(axlGetSelSet()); In this variable you'll store the database ID of the shape object that you clicked on
    The above code is just and example of how to select a shape, but you can apply this to any component in a design (symbols, vias, lines, etc.)
    Let me know if this is what  you're looking for.
  • kobe882424
    +1 kobe882424 over 3 years ago in reply to JuanCR
    Thanks JuanCR.
    the reason is that the pcb was completed  by a team. so the list(?enable)  needs to add "DYNTHEMALS" like this:
    axlSetFindFilter(?enabled `("noall"   "components"  "DYNTHEMALS") ?onButtons `("noall"  "components" ))
