  3. Unable to create a void within Dynamic Shape
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 4177
khuranav007
khuranav007 over 3 years ago
I have an existing dynamic shape on etch layer and want to add a void to it.
As such I am using axlPathStart() and axlDBCreateVoid() but the issue is that I get following error because the void starting point (x value) overlaps with shape's starting point (x value).
(SPMHDB-186): Void must be within the shape.
I can add 0.001 to get around this but is there something else?
Btw, axlDBOpenShape() does not appear reliable - it gives following warning (sometimes):
*WARNING* (axlDBOpenShape): A Shape is already open.
Thanks!
  • DE202408202727
    DE202408202727 over 3 years ago +1
    Try using axlPolyOperation in this instance. I generally find that dealing with polygons is easier than working with open shapes. axlDBOpenShape is reliable but, as it says, you can only have one shape…
  • mahimag
    mahimag over 3 years ago +1 suggested
    Also, Allegro datbase does not allow a void to be added to a shape of the void boundary touches or crosses the outer boundary of the shape. You can edit the outer boundary of the shape using the Polygon…
  • DE202408202727
    0 DE202408202727 over 3 years ago
    axlDBOpenShape is reliable but, as it says, you can only have one shape open at a time.
  • mahimag
    0 mahimag over 3 years ago
    Also, Allegro datbase does not allow a void to be added to a shape of the void boundary touches or crosses the outer boundary of the shape. You can edit the outer boundary of the shape using the Polygon operations.
  • khuranav007
    0 khuranav007 over 3 years ago in reply to DE202408202727
    Thanks Dave
  • khuranav007
    0 khuranav007 over 3 years ago in reply to mahimag
    Thanks Mahima
