  3. skill to create shape based on vias
  • State Suggested Answer
  • Replies 16
  • Answers 2
  • Subscribers 22
  • Views 15494
zpofrp
zpofrp over 2 years ago
Hi
Attached,
i want use skill to create a shape based on select via,but i can't wirte the skill.
 Play this video
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago +3 suggested
    Hi zpofrp ! Please refer this code. HoangKhoi. ; ##################################################################### axlCmdRegister("createShapeByVia" 'createShapeByVia ) (defun createShapeByVia…
  • zpofrp
    zpofrp over 2 years ago in reply to Hoangkhoipcb +1
    its very nice,thank you very much.
  • danle
    danle over 2 years ago in reply to Hoangkhoipcb +1
    your script saved me so much time! what would you do to make if work over multiple layers? i.e that the shape will be created over the whole via path, if the via is 1-4 you will have a shape in L1…
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago
    Hi zpofrp!
    HoangKhoi.
    (defun createShapeByVia ()
    vi_via = setof(e axlSubclassRoute(?field 'isEtch) axlIsVisibleLayer(strcat("VIA CLASS/" e )))
    if(length(vi_via) > 1 then
    axlUIConfirm( "Visible Via must one layer")
    else
    layer = car(vi_via)
    axlClearSelSet(vi_via)
    axlSetFindFilter(?enabled '(noall VIAS NAMEFORM) ?onButtons '(noall VIAS))
    mypopup = axlUIPopupDefine(nil (list (list "Done" 'axlFinishEnterFun) (list "Cancel" 'axlCancelEnterFun)))
    axlUIPopupSet( mypopup)
    while(axlSelect(?prompt "Please select an element...")
    Input_List = axlGetSelSet()
    axlClearSelSet()
    if(length(Input_List)>1 then
    tmp = nil
    net = car(Input_List)->net
    foreach(via Input_List
    foreach(via2 setof(e Input_List e->xy != via->xy)
    sizeVia1 = getSizeVia(via, layer)
    sizeVia2 = getSizeVia(via2, layer)
    lineWidth = max(sizeVia1,sizeVia2)
    r_path = axlPathStart(list( via->xy via2->xy ) lineWidth)
    r_path_poly = car(axlPolyFromDB(r_path ?line2poly t ?endCapType 'ROUND))
    tmp = cons(r_path_poly tmp)
    poly_tmp = car(axlPolyOperation(car(tmp) cdr(tmp) 'OR))
    if(poly_tmp->holes != nil then
    hole_list = nil
    foreach(h poly_tmp->holes
    hole_list = cons(car(axlPolyFromHole(h)) hole_list)
    poly_tmp = car(axlPolyOperation(poly_tmp hole_list 'OR))
    create_shape = axlDBCreateShape(poly_tmp t strcat("ETCH/" layer) net )
    (defun getSizeVia (via, layer)
    prog((sizeVia)
    pad_box = axlDBGetPad(via strcat("VIA CLASS/" layer) "regular")->bBox
    p1 = car(pad_box)
    p2 = xCoord(car(pad_box)) : yCoord(cadr(pad_box))
    p3 = xCoord(cadr(pad_box)) : yCoord(car(pad_box))
    sizeVia = max(axlDistance(p1 p2), axlDistance(p1 p3))
    return(sizeVia)
    • Vote Up +3 Vote Down
  • zpofrp
    0 zpofrp over 2 years ago in reply to Hoangkhoipcb
  • danle
    0 danle over 2 years ago in reply to Hoangkhoipcb
    if the via is 1-4 you will have a shape in L1, L2, L3 and L4
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to danle
    else
    layer = car(vi_via)
    axlClearSelSet()
    tmp = nil
    zlenVia = nil
    startEndVia = via->startEnd
    zlenVia = cons(list(axlViaZLength(car(startEndVia) cadr(startEndVia)) cadr(parseString(car(startEndVia) "/")) cadr(parseString(cadr(startEndVia) "/"))) zlenVia)
    hole_list = nil
    zlenVia = sortcar(zlenVia 'lessp) ; filter long length Via
    lastViaSE = lastelem(zlenVia)
    stLayer = member(cadr(lastViaSE) axlSubclassRoute(?field 'isEtch) )
    stLayer = reverse(member(caddr(lastViaSE) reverse(stLayer)))
    foreach(item stLayer
    create_shape = axlDBCreateShape(poly_tmp t strcat("ETCH/" item) net )
    prog((sizeVia)
    p1 = car(pad_box)
    return(sizeVia)
    Hi danle !
    Refer this code.
    Hoang Khoi.
  • danle
    thank you so much!
