  3. skill to create shape based on vias
  • State Suggested Answer
  • Replies 16
  • Answers 2
  • Subscribers 22
  • Views 15495
zpofrp
zpofrp over 2 years ago
Hi
Attached,
i want use skill to create a shape based on select via,but i can't wirte the skill.
 Play this video
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago +3 suggested
    Hi zpofrp ! Please refer this code. HoangKhoi. ; ##################################################################### axlCmdRegister("createShapeByVia" 'createShapeByVia ) (defun createShapeByVia…
  • zpofrp
    zpofrp over 2 years ago in reply to Hoangkhoipcb +1
    its very nice,thank you very much.
  • danle
    danle over 2 years ago in reply to Hoangkhoipcb +1
    your script saved me so much time! what would you do to make if work over multiple layers? i.e that the shape will be created over the whole via path, if the via is 1-4 you will have a shape in L1…
  • zpofrp
    0 zpofrp over 2 years ago in reply to Hoangkhoipcb
    I find one bug, show the pic1.
    big via and small via, the shape is hollow,same as pic1.
    I want to create shape same as pic2 or pic3.
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to zpofrp
    Here's a more complex alternative:
    axlCmdRegister("createShapeByVia" 'CreateShapeByVia)
    defun( CreateShapeByVia ()
    let((visViaSubclasses, subclass, etchLayer, popupAllActive, popupGrayOops, mark, (oopsCount 0), selectedVias, polys, nets, net, viaPairs, via1, via2, dia1, dia2, lineWidth, path, poly, oShape, shp)
    visViaSubclasses = setof(sc, axlSubclassRoute(?field, 'isEtch), axlIsVisibleLayer(strcat("VIA CLASS/", sc)))
    if(!onep(length(visViaSubclasses)) then
    axlUIConfirm("Only one etch layer can be visible")
    else
    subclass = car(visViaSubclasses)
    etchLayer = strcat("ETCH/", subclass); Use strcat("BOUNDARY/", subclass) if the shape needs to be dynamic
    axlClearSelSet()
    axlSetFindFilter(?enabled '(noall, vias), ?onButtons '(noall, vias))
    popupAllActive = axlUIPopupDefine(nil '(
    ("Done", "axlDBTransactionCommit(mark), axlFinishEnterFun()")
    ("Oops", "axlDBTransactionOops(mark), when(zerop(--oopsCount), axlUIPopupSet(popupGrayOops))")
    ("Cancel", "axlDBTransactionRollback(mark), axlCancelEnterFun()")
    popupGrayOops = axlUIPopupDefine(nil, '(
    mark = axlDBTransactionStart()
    while(axlSelect(?prompt "Select vias...")
    selectedVias = axlGetSelSet()
    axlClearSelSet()
    polys = nil
    nets = selectedVias ~>net
    net = cadar(sortcar(mapcar(lambda((n), list(length(setof(nt, nets, nt == n)), n)), unique(nets)), 'greaterp)); Select the net of the most number of vias
    viaPairs = CreateShapeByVia_PairCombinations(setof(v, selectedVias, v ->net == net))
    foreach(viaPair, viaPairs; Create a line or a shape polygon between each and every via
    via1 = car(viaPair)
    via2 = cadr(viaPair)
    dia1 = CreateShapeByVia_viaDia(via1, subclass)
    dia2 = CreateShapeByVia_viaDia(via2, subclass)
    if(dia1 == dia2 then
    lineWidth = max(dia1,dia2)
    path = axlPathStart(list(via1 ->xy, via2 ->xy), lineWidth)
    poly = car(axlPolyFromDB(path, ?line2poly t, ?endCapType 'ROUND)); Use a line polygon if the via pads are the same diameter
    else
    poly = CreateShapeByVia_circleCircleTangentialPoly(via1 ->xy, dia1 / 2, via2 ->xy, dia2 / 2); Use a tangential polygon if the via pads are different diameters
    polys = cons(poly, polys)
    when(polys
    poly = car(axlPolyOperation(car(polys), cdr(polys), 'OR)); Combine all the line polys into one polygon
    axlDBTransactionMark(mark)
    oShape = axlDBCreateOpenShape(poly, t, etchLayer, net)
    axlShapeDeleteVoids(oShape)
    shp = car(axlDBCreateCloseShape(oShape))
    when(shp
    axlShapeAutoVoid(shp); Try to void any objects that shouldn't be included. ie on a different net. Doesn't work well.
    oopsCount++
    axlUIPopupSet(popupAllActive)
    ;Return the via pad diameter from the selected subclass
    defun( CreateShapeByVia_viaDia (via @optional (subclass, "TOP"))
    let((pad, bbox)
    pad = axlDBGetPad(via, strcat("VIA CLASS/", subclass), "regular")
    bbox = pad ->bBox
    if(pad ->figureName == "CIRCLE" then
    max(abs(caadr(bbox) - caar(bbox)), abs(cadadr(bbox) - cadar(bbox))); Maximum of x and y extents.
    else
    axlDistance(car(bbox), cadr(bbox))
    ;Return a list of all the pair combinations of the objects passed.
    defun( CreateShapeByVia_PairCombinations (objs)
    let((obj1, objPairs)
    while(objs
    obj1 = car(objs)
    objs = cdr(objs)
    foreach(obj2, objs, objPairs = cons(list(obj1, obj2), objPairs))
    objPairs
    ; Create a polygon that encompasses the tangential boundaries of two circles of differeing sizes.
    defun( CreateShapeByVia_circleCircleTangentialPoly (cpt1, r1, cpt2, r2 @optional layer, netName, parent)
    let((x1, y1, x2, y2, ang1, ang2, ang, pt1, pt2, pt3, pt4, path, poly)
    x1 = car(cpt1), y1 = cadr(cpt1)
    x2 = car(cpt2), y2 = cadr(cpt2)
    ;en.wikipedia.org/.../Tangent_lines_to_circles
    ang1 = -atan2(y2-y1, x2 - x1)
    ang2 = asin((r2 - r1) / sqrt((x2 - x1)**2 + (y2 - y1)**2))
    ang = ang1 - ang2
    pt1 = list(x1 + r1 * sin(ang), y1 + r1 * cos(ang))
    pt3 = list(x2 + r2 * sin(ang), y2 + r2 * cos(ang))
    ang = ang1 + ang2
    pt2 = list(x1 - r1 * sin(ang), y1 - r1 * cos(ang))
    pt4 = list(x2 - r2 * sin(ang), y2 - r2 * cos(ang))
    path = axlPathStart(list(pt1, pt3))
    axlPathArcCenter(path, nil, pt4, t, cpt2)
    axlPathLine(path, nil, pt2)
    axlPathArcCenter(path, nil, pt1, t, cpt1)
    poly = car(axlPolyFromDB(path))
    when(layer, axlDBCreateShape(poly, t, layer, netName, parent))
    poly
  • DE202408202727
    else
    axlClearSelSet()
    axlClearSelSet()
    polys = nil
    via1 = car(viaPair)
    else
    when(polys
    when(shp
    oopsCount++
    let((pad, bbox)
    bbox = pad ->bBox
    else
    while(objs
    obj1 = car(objs)
    objs = cdr(objs)
    objPairs
    ang = ang1 - ang2
    ang = ang1 + ang2
    poly
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to DE202408202727
    This is a more complex solution but should get around your problem.
  • zpofrp
    0 zpofrp over 2 years ago in reply to DE202408202727
    nice, thanks you very much.
