  3. skill to create shape based on vias
  • State Suggested Answer
  • Replies 16
  • Answers 2
  • Subscribers 22
  • Views 15501
zpofrp
zpofrp over 2 years ago
Hi
Attached,
i want use skill to create a shape based on select via,but i can't wirte the skill.
 Play this video
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago +3 suggested
    Hi zpofrp ! Please refer this code. HoangKhoi. ; ##################################################################### axlCmdRegister("createShapeByVia" 'createShapeByVia ) (defun createShapeByVia…
  • zpofrp
    zpofrp over 2 years ago in reply to Hoangkhoipcb +1
    its very nice,thank you very much.
  • danle
    danle over 2 years ago in reply to Hoangkhoipcb +1
    your script saved me so much time! what would you do to make if work over multiple layers? i.e that the shape will be created over the whole via path, if the via is 1-4 you will have a shape in L1…
  • SambaKantipudi
    0 SambaKantipudi over 1 year ago in reply to zpofrp
    Hello eDave
    Thanks for the wonderful function, saves a lot of time and manual workBlush
    Is it possible to modify the SKILL, to let USER select the layer for Shape creation, when VIAS are selected?
    Like:
    cond = '("Active Layer", "Inner Layers")
    action = axlUIMultipleChoice("Select an option", cond, "Create Shape")
    Active Layer -> Shape is created on Active Layer
    Inner Layer -> Shape is created on all Inner Layers, excluding TOP & BOTTOM.
    Aslo, thanks to zpofrp and Hoangkhoipcb
    BR
    Samba
  • DE202408202727
    0 DE202408202727 over 1 year ago in reply to SambaKantipudi
    I currently can't upload. Please contact me directly.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to SambaKantipudi
    Dear SambaKantipudi,
    I've adjusted the code based on your idea. However, I'm unable to upload the code to this post.
    Please contact me at hoangkhoipcb_@gmail_com, and I'll send you the code.
    Best regards,
    HoangKhoi
  • MikeNV
    0 MikeNV over 1 year ago in reply to Hoangkhoipcb
    Hi Hoangkhoipcb / eDave,
    Can you please share the skill script with the layer selection option? mwarner@nvidia.com
    Br,
    Michael
  • DE202408202727
    0 DE202408202727 over 1 year ago in reply to MikeNV
    See attached
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/137/createShapeByVia.zip
