  3. I wanted to create a void or Connect with shape
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 2948
Henry Monro
Henry Monro over 2 years ago
I would be thankful if someone can help me in this manner.
I wanted to create a cline to connect the hole with the shape where there are DRC of Constraint: Drill Hole to Shape Same Net Spacing and there are lots of DRCS on each layer other solution is that if any of you can help in creating a void on holes.
I have attached a snap for reference.
  • VVRD
    0 VVRD over 2 years ago
    You want to set clearance for thru hole vias? If yes, you can set shape clearance values in Global Dynamic Shape Parameters.
  • DE202408202727
    0 DE202408202727 over 2 years ago
    I'm not sure exactly what you want here and what the "holes" are. If they are vias with a pad on the same layer then something like this could work:
    drcs = setof(drc, axlDBGetDesign() ->drcs, drc ->name == "Drill Hole to Shape Same Net Spacing"
    foreach(drc, drcs
    via = car(setof(v, drc ->violations, v ->objType == "via"))
    shp = car(setof(v, drc ->violations, v ->objType == "shape"))
    gap = axlAirGap(via, shp, nil, 'enhanced)
    loc1 = via ->xy
    loc2 = if(car(parseString(gap ->layer1, "/")) == "VIA CLASS" then gap ->location2 else gap ->location1)
    subclass = cadr(parseString(drc ->layer, "/"))
    pad = axlDBGetPad(via, strcat("VIA CLASS/", subclass), "REGULAR")
    seg = axlPathGetLastPathSeg(car(pad ->figure))
    width = 2 * axlDistance(axlPathSegGetEndPoint(seg), axlPathSegGetArcCenter(seg))
    path = axlPathStart(list(loc1, loc2), width)
    axlDBCreatePath(path, strcat("ETCH/", subclass), via ->net)
  • Henry Monro
    0 Henry Monro over 2 years ago in reply to DE202408202727
    I am using the below code but its not working on multiple selections its just working on first and then finishes.
    If you can help please
    count=0
    axlSetFindFilter(?enabled list("noall") ?onButtons list("noall"))
    axlSetFindFilter( ?enabled '("alltypes") ?onButtons "DRCS")
    axlSelect(?prompt "\nSelect DRCS from the layout")
    drcs=axlGetSelSet()
    length_l_drcs=length(drcs)
    println("length_l_drcs")
    println(length_l_drcs)
    count=0
    foreach(drc, drcs
    if(drc->waived==nil && drc->name== "Drill Hole to Shape Same Net Spacing" then
    via = car(setof(v, drc->violations, v ->objType == "via"))
    shp = car(setof(v, drc->violations, v ->objType == "shape"))
    loc1 = via->xy
    println(gap->layer1)
    loc2 = if(car(parseString(gap->layer1, "/")) == "VIA CLASS" then gap->location2 else gap->location1)
    println(drc->layer)
    subclass = cadr(parseString(drc->layer, "/"))
    ;seg = axlPathGetLastPathSeg(car(pad->figure))
    ;width = 2 * axlDistance(axlPathSegGetEndPoint(seg), axlPathSegGetArcCenter(seg))
    path = axlPathStart(list(loc1, loc2), 2)
    axlDBCreatePath(path, strcat("ETCH/", subclass), via->net)
    count++
    println(count)
