  3. Place Replicate Module
  • State Suggested Answer
  • Answers 1
  • Subscribers 23
  • Views 4774
Henry Monro
Henry Monro over 2 years ago
Hi
I need a help in the automation using skill language in the process of Place Replicate Apply so far I have created the symbols using below:
axlDBCreateSymbol("C219", list(4353, 2070), nil, 0)
(dbid:00000142F0C78EF8 nil)
axlDBCreateSymbol("C215", list(4353, 2070), nil, 0)
(dbid:00000142BAD212D8 nil)
axlDBCreateSymbol("KM_CSI_S1", list(4453, 2070), nil, 0)
(dbid:00000142EF4A21B8 t)
Now I wanted to select these Symbols and apply the Place Replicate Apply using the module files that I have the .mdd file and make it intelligent and place the module on my desired location.
I am unable to find the command to perform this operation using skill language.
Help is required in this regard.
I have created below Three Symbols:
Now I have to automate the process that when I select all three of them then I right click then goes to the option Place Replicate Apply then selects the desired module so it becomes something as below in snap which is my desired goal to place on any location of my interest:
Please help in this regard.
  • sravan padarthy
    sravan padarthy over 2 years ago in reply to Henry Monro +1 suggested
    saw these two functions in another post, hope they are helpful to you: axlDBCreateModuleDef, axlDBCreateModuleInstance Compare Structures using skill - Allegro X Scripting - Skill - PCB Design & IC Packaging…
  • sravan padarthy
    0 sravan padarthy over 2 years ago
    Cadence already has that option in "placement edit" right, does skill offers any advantage?
  • Henry Monro
    0 Henry Monro over 2 years ago in reply to sravan padarthy
    I knew this option in "placement edit" but I am in need of the advantage from cadence to provide the skill command for Place Replicate Apply.
  • sravan padarthy
    0 sravan padarthy over 2 years ago in reply to Henry Monro
    Compare Structures using skill - Allegro X Scripting - Skill - PCB Design & IC Packaging (Allegro X) - Cadence Community
  • evseshu
    0 evseshu over 1 year ago in reply to sravan padarthy
    I unable to find Placement replicate create and placement repliacte apply in Cadence 23.1 tool please help me how to enable
