  3. Place Module .mdd file without using hierarchical block...
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 4350
Place Module .mdd file without using hierarchical blocks
Hussain Aalim
Hussain Aalim over 2 years ago
I am trying to automate “Place Module” functionality of allegro by creating a module .mdd file and placing the module but I don’t want to use hierarchical blocks. Please help me with the automation of placing the modules without hierarchical blocks.
For this, I have created a module (.mdd) and linked it with the schematic using “Annotate” functionality of OrCAD under “PCB Editor Reuse” tab.
To use that module in the allegro, I had to place hierarchical blocks in the actual schematic that is going to be used for the design, and then linked the hierarchical blocks with the .dsn file of the “Reuse module” schematic.
After that we annotated the schematic to use the Reuse Module in a new design.
Later on, reuse module gets called by importing logic files and starts appearing under Placement section of “Module Instances” in allegro.
There’s only one challenge that I want to overcome: this method of creating reuse modules requires a dependency on hierarchical blocks. The main limitation here is that I cannot use hierarchical blocks in my designs. Please provide an alternative solution that allows me to call modules intelligently without the dependency on hierarchical blocks. I would also like to have skill code available for this solution.
Thanks in advance.
  • mahimag
    0 mahimag over 2 years ago
    Hussain Aalim , If you want to directly create and place modules in board file, you can use Tools > Create Module directly without schematic involvement. In board, you can also use Place Replicate Module flow.
    Go to Placement Edit application mode and when you write click on a group of objects you have an option to create Place Replicate modules
  • mahimag
    Also for the SKILL related to modules, there is another thread which I see on this forum which talks about it
    community.cadence.com/.../place-replicate-module
  • Hussain Aalim
    0 Hussain Aalim over 2 years ago in reply to mahimag
    Hi
    When I place the module mdd using the axlDBCreateModuleInstance it changes the net names so how can I fix this issue to let the net names be same (it adds the suffix in the net names as provided in the axlDBCreateModuleInstance command) as shown below:
    modinst = axlDBCreateModuleInstance("inst" "comp_mod" '(4181 2456) 0 2)
    The command axlDBCreateModuleInstance adds the "inst" name in  the suffix of each of the net names so how can I route that net.
    Thanks in advance
  • mahimag
    0 mahimag over 2 years ago in reply to Hussain Aalim
    In Place > Module flow, by default prefix or suffix is added when you place module instance. To disable this behavior try variable "module_instance_no_rename" in Setup > User Preferences > Placement > General
