  3. how to Fetch parameters of the Options window
  • State Verified Answer
  • Subscribers 20
  • Views 1540
Hoangkhoipcb
Hoangkhoipcb 8 months ago
Hi everyone,
Methods for identifying form handles and fetching parameters from the dynamic Options sidebar in Cadence Allegro
Any code snippets or references to the documentation would be greatly appreciated.
Thank you.
  • Hoangkhoipcb
    Hoangkhoipcb 8 months ago in reply to JuanCR +1 verified
    Hi JuanCR, My goal is to extract the active line width from the system's Options form upon the termination of add connect . Since I'm not the one creating the form, I need to know how to reference that…
  • JuanCR
    0 JuanCR 8 months ago
    Hi Hoangkhoipcb
    What do you mean by "identifying form handles"? If you want to control a specific form in the tool, my personal method is to record a script manipulating the form and then inspect the .scr file to see how the tool calls that specific form. Then I can just run the script within SKILL with axlShellPost. Is that what you're looking for?
  • Hoangkhoipcb
    +1 Hoangkhoipcb 8 months ago in reply to JuanCR
    Hi JuanCR,
    My goal is to extract the active line width from the system's Options form upon the termination of  add connect. Since I'm not the one creating the form, I need to know how to reference that specific field's value via SKILL.
    I would like to fetch the values from the Add Connect parameters found under: Setup -> Design Parameters -> Route -> Add Connect.
    Best & Regards,
    HoangKhoi
