  2. Allegro X Scripting - TCL
  3. TCl script to replace selected parts with a component from...
  • State Verified Answer
  • Replies 18
  • Subscribers 15
  • Views 11536
TCl script to replace selected parts with a component from library
soliman1991
soliman1991 over 2 years ago
I need to replace components in a schematic page with parts from the library, I tried DboPage_ReplaceInst, but the documentation is very vague.
Here is my attempt for reference:
set selected [GetSelectedObjects]
puts $selected
set newPackageStr {CAP CER 0.1UF 10V X8M 0201} #that is the package name in the library
set lStatus [DboState]
set lSession $::DboSession_s_pDboSession
DboSession -this $lSession
set pLibName [file normalize {d:\random\Library.olb}]
set lLibName [DboTclHelper_sMakeCString $pLibName]
set lLib [$lSession GetLib $lLibName $lStatus]
set LibraryName [DboTclHelper_sMakeCString]
$lLib GetName $LibraryName
set newPackageName [DboTclHelper_sMakeCString newPackageStr]
set newPackage [$lLib GetPackage $newPackageName $lStatus]
foreach obj $selected {
    set device [$obj GetDevice $lStatus]
    DboPage_ReplaceInst $obj $newPackageName $newPackage $device $lStatus 0 0 1 1
  • CadAP
    CadAP over 2 years ago in reply to soliman1991 +2 verified
    HI soliman1991 I believe you have take the dboLibPart and Dbodevice form the library from which you want to change it. Please try the below code just replace the location C:/Users/test/Desktop…
  • CadAP
    CadAP over 2 years ago +1
    Hello Soliman1991, Please use the below code to replace the selected part with a part from another library. set selected [GetSelectedObjects] # puts $selected set lPackage "C" ;#make sure the package…
  • PatEscher
    PatEscher over 2 years ago in reply to CadAP +1
    what would be the difference between ReplaceInst and ReplacePart then? Are we really replacing the instances by this command or are we replacing the complete Parts, so that it automatically replaces all…
  • CadAP
    0 CadAP over 2 years ago
    Hello Soliman1991,
    # puts $selected
    set lPackage "C" ;#make sure the package name in the library.
    # set device [$obj GetDevice $lStatus]
    # $lPage ReplaceInst $obj $newPackageStr $lPart $device $lStatus 0 0 1 1
    ReplacePart "$pLibName" "$lPackage" "$lPackage.NORMAL" ""
  • PatEscher
    0 PatEscher over 2 years ago in reply to CadAP
    Are we really replacing the instances by this command or are we replacing the complete Parts, so that it automatically replaces all instances using this part?
  • soliman1991
    0 soliman1991 over 2 years ago in reply to CadAP
    Unfortunately ReplacePart doesn't preserve RefDes, anyway around that?
  • CadAP
    0 CadAP over 2 years ago in reply to soliman1991
    Hello Soliman1991,
    Please use the below code to replace the selected part with a part from another library with preserver refdef.
    # puts $selected
    set newPackageStr [DboTclHelper_sMakeCString "C"] ;#that is the package name in the library
    set lPart [$obj GetPart $lStatus]
    set lPage [$obj GetOwner]
    $lPage ReplaceInst $obj $newPackageStr $lPart $device $lStatus 1 0 1 1
    # ReplacePart "$pLibName" "$lPackage" "$lPackage.NORMAL" ""
  • CadAP
    0 CadAP over 2 years ago in reply to PatEscher
    Hi PatEscher,
    Yes, ReplacePart is completing replacing the Part with the new one taken from library. While in ReplaceInst we can preserve previous value.
