  2. Allegro X Scripting - TCL
  3. TCl script to replace selected parts with a component from...
  • State Verified Answer
  • Replies 18
  • Subscribers 15
  • Views 11537
TCl script to replace selected parts with a component from library
soliman1991
soliman1991 over 2 years ago
I need to replace components in a schematic page with parts from the library, I tried DboPage_ReplaceInst, but the documentation is very vague.
Here is my attempt for reference:
set selected [GetSelectedObjects]
puts $selected
set newPackageStr {CAP CER 0.1UF 10V X8M 0201} #that is the package name in the library
set lStatus [DboState]
set lSession $::DboSession_s_pDboSession
DboSession -this $lSession
set pLibName [file normalize {d:\random\Library.olb}]
set lLibName [DboTclHelper_sMakeCString $pLibName]
set lLib [$lSession GetLib $lLibName $lStatus]
set LibraryName [DboTclHelper_sMakeCString]
$lLib GetName $LibraryName
set newPackageName [DboTclHelper_sMakeCString newPackageStr]
set newPackage [$lLib GetPackage $newPackageName $lStatus]
foreach obj $selected {
    set device [$obj GetDevice $lStatus]
    DboPage_ReplaceInst $obj $newPackageName $newPackage $device $lStatus 0 0 1 1
  • CadAP
    CadAP over 2 years ago in reply to soliman1991 +2 verified
    HI soliman1991 I believe you have take the dboLibPart and Dbodevice form the library from which you want to change it. Please try the below code just replace the location C:/Users/test/Desktop…
  • CadAP
    CadAP over 2 years ago +1
    Hello Soliman1991, Please use the below code to replace the selected part with a part from another library. set selected [GetSelectedObjects] # puts $selected set lPackage "C" ;#make sure the package…
  • PatEscher
    PatEscher over 2 years ago in reply to CadAP +1
    what would be the difference between ReplaceInst and ReplacePart then? Are we really replacing the instances by this command or are we replacing the complete Parts, so that it automatically replaces all…
  • PatEscher
    0 PatEscher over 2 years ago in reply to CadAP
    mhh, ok still not 100% clear.
    So I replace a selected component in the schematic (this is the placed instance) with the full definition of the component coming from the library.
    Is is like a 'delete' and an 'add" then?
    So I will lose as mentioned in the other post the RefDes (ok we could store the value and set it afterwards) and also all user modification done, right?
    Is there any performance difference between ReplacePart and ReplaceInst ?
  • soliman1991
    0 soliman1991 over 2 years ago in reply to CadAP
    Thanks again, this code changes the parts "Graphics" but it keep all other properties as the old part including value, part number, etc.. Also if I tried to move the part in the schematics, capture crashes.
  • soliman1991
    0 soliman1991 over 2 years ago in reply to PatEscher
    FYI, I tried storing the RefDes and swapped the part using ReplacePart. Capture crashes after trying to write the RefDes back. Did you get any luck with that?
  • CadAP
    0 CadAP over 2 years ago in reply to soliman1991
    Hi ,
    Please add the command "DboTclHelper_sEvalPage $lPage" after command "$lPage ReplaceInst $obj $newPackageStr $lPart $device $lStatus 1 0 1 1".
    # puts $selected
    set newPackageStr [DboTclHelper_sMakeCString "C"] ;#that is the package name in the library
    set lPart [$obj GetPart $lStatus]
    set lPage [$obj GetOwner]
    # ReplacePart "$pLibName" "$lPackage" "$lPackage.NORMAL" ""
  • CadAP
    0 CadAP over 2 years ago in reply to PatEscher
    HI,
    ReplaceInst(pOldInst, packageName, part, device, status, bUpdate,
    Class : DboPage(DboBaseObject):
    bNewVersion, bPreserverefDes, bDeleteOldInst = 1) : returns DboPlacedInst
    Parameters:
    pOldInst: DboPlacedInst *
    packageName: CString &
    part: DboLibPart *
    device: DboDevice *
    status: DboState &
    bUpdate: int
    bNewVersion: int
    bPreserverefDes: int
    ReplacePart(libName, pkgName, partName, device)
    Parameters:
    libName: char const *
    pkgName: char const *
    partName: char const *
    device: char const *
    See the arguments required for ReplaceInst and ReplacePart. ReplaceInst have argument to bPreserverefDes and bDeleteOldInst.
    Yes
    with ReplacePart --Yes.
    Performance affect when accessing library over network(if there any network slowness or low latency) .
