  2. Allegro X Scripting - TCL
  3. TCl script to replace selected parts with a component from...
  • State Verified Answer
  • Replies 18
  • Subscribers 15
  • Views 11545
TCl script to replace selected parts with a component from library
soliman1991
soliman1991 over 2 years ago
I need to replace components in a schematic page with parts from the library, I tried DboPage_ReplaceInst, but the documentation is very vague.
Here is my attempt for reference:
set selected [GetSelectedObjects]
puts $selected
set newPackageStr {CAP CER 0.1UF 10V X8M 0201} #that is the package name in the library
set lStatus [DboState]
set lSession $::DboSession_s_pDboSession
DboSession -this $lSession
set pLibName [file normalize {d:\random\Library.olb}]
set lLibName [DboTclHelper_sMakeCString $pLibName]
set lLib [$lSession GetLib $lLibName $lStatus]
set LibraryName [DboTclHelper_sMakeCString]
$lLib GetName $LibraryName
set newPackageName [DboTclHelper_sMakeCString newPackageStr]
set newPackage [$lLib GetPackage $newPackageName $lStatus]
foreach obj $selected {
    set device [$obj GetDevice $lStatus]
    DboPage_ReplaceInst $obj $newPackageName $newPackage $device $lStatus 0 0 1 1
  • CadAP
    CadAP over 2 years ago in reply to soliman1991 +2 verified
    HI soliman1991 I believe you have take the dboLibPart and Dbodevice form the library from which you want to change it. Please try the below code just replace the location C:/Users/test/Desktop…
  • CadAP
    CadAP over 2 years ago +1
    Hello Soliman1991, Please use the below code to replace the selected part with a part from another library. set selected [GetSelectedObjects] # puts $selected set lPackage "C" ;#make sure the package…
  • PatEscher
    PatEscher over 2 years ago in reply to CadAP +1
    what would be the difference between ReplaceInst and ReplacePart then? Are we really replacing the instances by this command or are we replacing the complete Parts, so that it automatically replaces all…
  • soliman1991
    0 soliman1991 over 2 years ago in reply to CadAP
    This fixed the crash, but it preserved more than what it should. I only need to preserve refdes and update everything else.
  • CadAP
    0 CadAP over 2 years ago in reply to soliman1991
    Hi soliman1991,
    Please use command with below arguments:
    $lPage ReplaceInst $obj $newPackageStr $lPart $device $lStatus 0 0 1 1
    This will preserve the refdes and rest values will be updated from the library.
  • soliman1991
    Hello! Thank you so much for your help. I tried the change suggested, and it still only change "Graphic" property, it still preserves all other properties.
  • CadAP
    +1 CadAP over 2 years ago in reply to soliman1991
    HI soliman1991
    Please try the below code just replace the location C:/Users/test/Desktop/generateOlb/LIBRARY2.OLB with your .olb location.
    At my end it changes all properties value except refdes.
    set package "C"
    set newPackageStr [DboTclHelper_sMakeCString "$package"] ;#that is the package name in the library
    set newPartStr "$package.Normal" ;#that is the package name in the library
    set pLibName [DboTclHelper_sMakeCString "[file normalize {C:/Users/test/Desktop/generateOlb/LIBRARY2.OLB}]"]
    set lLib [$lSession GetLib $pLibName $lStatus]
    set lnewpartIter [$lLib NewPartsIter $lStatus]
    set lPart [$lnewpartIter NextPart $lStatus]
    set nm [DboTclHelper_sMakeCString]
    while {$lPart != "NULL"} {
    set lDbopackg [$lPart GetPackagePtr]
    set lDevice [$lDbopackg GetDevice 0 $lStatus]
    # puts $lDevice
    # puts $lPart
    $lPart GetName $nm
    set lPartname [DboTclHelper_sGetConstCharPtr $nm]
    # puts [DboTclHelper_sGetConstCharPtr $nm]
    if {$lPartname == "$newPartStr"} {
    # puts "changing"
    set lPage [$obj GetOwner]
    $lPage ReplaceInst $obj $newPackageStr $lPart $lDevice $lStatus 0 0 1 1
    DboTclHelper_sEvalPage $lPage
    delete_DboLibPartsIter $lnewpartIter
    Please try and let me know your fedback
    • Vote Up +2 Vote Down
  • soliman1991
    This worked!! Thank you so much.
