  2. Allegro X Scripting - TCL
  3. Is there a way to get all parts connected to a flat-net...
  • State Verified Answer
  • Subscribers 14
  • Views 3320
Is there a way to get all parts connected to a flat-net?
Jadystone
Jadystone over 2 years ago
I am trying to use TCL to check all capcitors voltage whether is below permitting voltage. So I first get a flatnet which net name gives me the voltage information such as VCC3.3. Then I iterate all capcitors connected to the flatnet and check the description of the capcitor to get rating voltage. I compare the net allowing voltage with the rating voltage from capcitor. If they are not matching, I print a warnig out
  • CadAP
    CadAP over 2 years ago in reply to Jadystone +1 verified
    Please see the below code for getting flat nets: set lSession $::DboSession_s_pDboSession DboSession -this $lSession set lNullObj NULL set lStatus [DboState] set pDesign [$lSession GetActiveDesign…
  • CadAP
    0 CadAP over 2 years ago
     Jadystone
    Please find the below code:
    It will check the property value Rated Voltage and pin connected wire name if both different value, then it will report pinname.
    set object [GetSelectedObjects]
    set lPropCString [DboTclHelper_sMakeCString "Rated Voltage"]
    set lPartRefCString [DboTclHelper_sMakeCString "Part Reference"]
    set lPropValCString [DboTclHelper_sMakeCString ]
    set lPartRefValCString [DboTclHelper_sMakeCString ]
    set lPinCString [DboTclHelper_sMakeCString ]
    set lWireCString [DboTclHelper_sMakeCString ]
    set lNetCString [DboTclHelper_sMakeCString ]
    set lState [$object GetEffectivePropStringValue $lPropCString $lPropValCString]
    set lState [$object GetEffectivePropStringValue $lPartRefCString $lPartRefValCString]
    set lVoltage "[DboTclHelper_sGetConstCharPtr $lPropValCString]"
    set lPartRef "[DboTclHelper_sGetConstCharPtr $lPartRefValCString]"
    set lNullObj NULL
    set lIter [$object NewPinsIter $lStatus]
    #get the first pin of the part
    set lPin [$lIter NextPin $lStatus]
    while {$lPin !=$lNullObj } {
    $lPin GetPinName $lPinCString
    set lPinName [DboTclHelper_sGetConstCharPtr $lPinCString]
    set lWire [$lPin GetWire $lStatus]
    set lNet [$lPin GetNet $lStatus]
    if {$lWire != $lNullObj || $lNet != $lNullObj} {
    $lWire GetNetName $lWireCString
    # $lWire GetNetName $lNetCString
    set lWireName [DboTclHelper_sGetConstCharPtr $lWireCString]
    if {$lWireName != $lVoltage } {
    puts "Comp with Refdes=$lPartRef has pin $lPinName has connected to Net $lWireName but volatge rating of comp is $lVoltage"
    #get the next pin of the part
    delete_DboPartInstPinsIter $lIter
    Hope it helps!
  • Jadystone
    0 Jadystone over 2 years ago in reply to CadAP
    CadAP,
    Maybe I didn't describe it clearly.  My question is how to obtain the flatnet of a wire connected to a part's pin.
    My idea is below.
    1. Iterating all capcitors of my design.  I determined that the device is a capacitor by PN prefix.
    2. I get the voltage (V1) of the capcitor from its description.
    3. I iterate all the pins of a capcitor to get the connected wire's flatnet (flatnet1) which is not net name.
    4. I compare the flatnet  (flatnet1)  with a given flatnet  (flatnet2)  which I know its voltage (V2) on .
    5. If they are equal (flatnet1=flatnet2), I will compare whether V1 < V2.
    6. If false, put out a warning message.
    My question is the 3rd step.  How  to get the flat net of a wire.
  • Jadystone
    My tcl code work. It can only work on the top schematic which has a same netname for a net.  But It cannot work into the hierarchical block in which has a differient netname.  I don't how to get the flat net of a wire.
  • CadAP
    +1 CadAP over 2 years ago in reply to Jadystone
    set lNullObj NULL
    set pDesign [$lSession GetActiveDesign]
    set lFlatNetsIter [$pDesign NewFlatNetsIter $lStatus]
    #get the first flat net of design
    set lFlatNet [$lFlatNetsIter NextFlatNet $lStatus]
    while {$lFlatNet!=$lNullObj} {
    #placeholder: do your processing on $lFlatNet
    set lNetName [DboTclHelper_sMakeCString]
    $lFlatNet GetName $lNetName
    #get the next flat net of design
    puts [DboTclHelper_sGetConstCharPtr $lNetName]
    delete_DboDesignFlatNetsIter $lFlatNetsIter
  • Jadystone
    It work!
    Thank you very much.
