  2. Allegro X Scripting - TCL
  3. Getting Diode Name
  • State Verified Answer
  • Subscribers 14
  • Views 2967
Getting Diode Name
karthikeyank
karthikeyank over 1 year ago
HI,
I was trying get the part name starts with the letter k and diode name. i can be able to retrieve the part name. i dont know how to access the diode. can anyone plz help me out.
Expected Output -
Part Name: K00_012
Diode Name: D00_012
Program:
for {set j 0} {$j < $objlength} {incr j} {
set lPage [lindex $selectedobjs $j]
set lPageNameCS [DboTclHelper_sMakeCString]
$lPage GetName $lPageNameCS
set lPageName [DboTclHelper_sGetConstCharPtr $lPageNameCS]
#puts $lPageName
set PlIter [$lPage NewPartInstsIter $lStatus]
set lPart [$PlIter NextPartInst $lStatus]
while {$lPart != $lNullObj } {
set lReferenceName [DboTclHelper_sMakeCString]
$lPart GetReference $lReferenceName
set lReferenceNameS [DboTclHelper_sGetConstCharPtr $lReferenceName]
#puts $lReferenceNameS
set firstLetter [string range $lReferenceNameS 0 0]
if {$firstLetter == "K" } {
set lOccCount [$lPart GetOccurrencesCount]
for {set i 0} {$i < $lOccCount} {incr i} {
set lOcc [$lPart GetOccurrencesAtPos $i]
set lReferenceName1 [DboTclHelper_sMakeCString]
$lOcc GetPathName $lReferenceName1
set lReferenceNameS1 [DboTclHelper_sGetConstCharPtr $lReferenceName1]
puts $lReferenceNameS1
set inpPrse [lindex [split $lReferenceNameS1 "/"] 1]
set lIter [$lPart NewPinsIter $lStatus]
set lPin [$lIter NextPin $lStatus]
while {$lPin != $lNullObj } {
set lPinName [DboTclHelper_sMakeCString]
$lPin GetPinName $lPinName
set lPinName [DboTclHelper_sGetConstCharPtr $lPinName]
if {[string first "+" $lPinName] >= 0} {
puts $inpPrse
#---How to find diode name
delete_DboPartInstPinsIter $lIter
delete_DboPagePartInstsIter $PlIter
  • karthikeyank
    karthikeyank over 1 year ago in reply to CadAP +1
    Actually, my requirement is I want to compare K Part and Connected Diode part is same name just k and d difference. For Ex: My K part is: K 00_012 means Diode Name Should be: D00_012 By using this…
  • karthikeyank
    karthikeyank over 1 year ago in reply to CadAP +1 verified
    Thanks for the support. While using above code: GetOwner Name returns the Diode Name. Like lRefName --> D00_14 lPrentRfdes--> D00_14 lConnPin this loop didn't return the K Partname. So, I've Updated…
  • CadAP
    0 CadAP over 1 year ago
    karthikeyank
    You can use regexp to check the word start with K or D.
    for example, if {[regexp {^(K|D)} $lReferenceNameS] == 1} {do your processing.}
    Try and let me know your feedback.
  • karthikeyank
    0 karthikeyank over 1 year ago in reply to CadAP
    For Ex: My K part is: K00_012 means Diode Name Should be: D00_012
    By using this: if {[regexp {^(K|D)} $lReferenceNameS] == 1}
    It will return every name. But I'm not able to find where Diode was connected.
    Error Case: For ex: K00_012->D00_013 and K00_013->D00_012
    I want to find these kinda cases. so, I want to get the Diode name by connections.
    Karthikeyan
  • CadAP
    0 CadAP over 1 year ago in reply to karthikeyank
    karthikeyank  I am sharing a sample code below; it will dump the connectivity of pin with diode like below.
    Where K is starting letter of refdes of a part and D is for Doide.
    K00_13-->D00_13
    K00_012-->D00_012
    K00_14-->D00_14
    K00_15-->D00_15
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lStatus [DboState]
    set lDesign [$lSession GetActiveDesign]
    set lSchi_Name [DboTclHelper_sMakeCString]
    set lPartCount 0
    set lReferenceName [DboTclHelper_sMakeCString ]
    set lPropName1 [DboTclHelper_sMakeCString ]
    set lPropValue [DboTclHelper_sMakeCString]
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    #get the first schematic view
    set lView [$lSchematicIter NextView $lStatus]
    # set lPage_Name [DboTclHelper_sMakeCString]
    while { $lView != $lNullObj} {
    #dynamic cast from DboView to DboSchematic
    set lSchematic [DboViewToDboSchematic $lView]
    $lSchematic GetName $lSchi_Name
    set lPagesIter [$lSchematic NewPagesIter $lStatus]
    #get the first page
    set lPage [$lPagesIter NextPage $lStatus]
    # puts [DboTclHelper_sGetConstCharPtr $lSchi_Name]
    while {$lPage!=$lNullObj} {
    # puts [DboTclHelper_sGetConstCharPtr $lPage_Name]
    set lPartInstsIter [$lPage NewPartInstsIter $lStatus]
    #get the first part inst
    set lInst [$lPartInstsIter NextPartInst $lStatus]
    while {$lInst!=$lNullObj} {
    #dynamic cast from DboPartInst to DboPlacedInst
    set lPlacedInst [DboPartInstToDboPlacedInst $lInst]
    if {$lPlacedInst != $lNullObj} {
    set lObjType [$lPlacedInst GetObjectType]
    if {$lObjType == 13} {
    #placeholder: do your processing on $lPlacedInst
    $lPlacedInst GetReference $lReferenceName
    set lRefName [DboTclHelper_sGetConstCharPtr $lReferenceName]
    if {[regexp {^D} $lRefName]== 1} {
    # puts $lRefName
    set lPinIter [$lPlacedInst NewPinsIter $lStatus]
    set lPin [$lPinIter NextPin $lStatus]
    while {$lPin != $lNullObj} {
    # puts $lPin
    set lWire [$lPin GetWire $lStatus]
    if {$lWire != $lNullObj} {
    set lConnpinIter [$lWire NewPortInstsIter $lStatus $::IterDefs_PORTS]
    set lConnPin [$lConnpinIter NextPortInst $lStatus]
    while {$lConnPin != $lNullObj} {
    # puts $lConnPin
    set lPrentObject [$lConnPin GetOwner]
    $lPrentObject GetReference $lPropName1
    set lPrentRfdes [DboTclHelper_sGetConstCharPtr $lPropName1]
    if {[regexp {^K} $lPrentRfdes] == 1 } {
    puts "$lPrentRfdes-->$lRefName"
    # puts $lRefName
    #get the next part inst
    delete_DboPagePartInstsIter $lPartInstsIter
    #get the next page
    delete_DboSchematicPagesIter $lPagesIter
    #get the next schematic view
    delete_DboLibViewsIter $lSchematicIter
    Try and let me know your comments
  • karthikeyank
    +1 karthikeyank over 1 year ago in reply to CadAP
    While using above code: GetOwner Name returns the Diode Name. Like lRefName -->D00_14 lPrentRfdes--> D00_14
    So, I've Updated the code now it's working fine.
    Program:
    set selectedobjs [GetSelectedPMItems]
    set objlength [llength $selectedobjs]
    set lNullObj NULL
    set lPartCount 0
    #puts $lRefName
    set lWireIter1 [$lWire NewConnectedWiresIter $lStatus]
    set lWire2 [$lWireIter1 NextWire $lStatus]
    while {$lWire2!=$lNullObj} {
    set lConnpinIter [$lWire2 NewPortInstsIter $lStatus $::IterDefs_PORTS]
    #puts $lConnPin
    #puts $lPrentRfdes
  • CadAP
    karthikeyank
    Good to know it helped.
    Thanks!
