  2. Allegro X Scripting - TCL
  3. How to select a project and save it with Tcl Command
  • State Suggested Answer
  • Replies 15
  • Answers 1
  • Subscribers 14
  • Views 7908
Morgan
Morgan over 1 year ago
Hi friends of the community,
I want to use Tcl Command to select the last opened project name(or library) in capture cis, such as .dsn(.olb), and then, save and close it, but I encounter some troubles:
1.When I iter all open designs in the session with 3.2.5, it get the design name, but not listed in the order in which they were opened, so I can't find the last opened project; and sometimes, it listed the project name I have closed;
2.When I try to select the .dsn or .olb name use <ui::PMActivate "d:/cadence/work/test/mytest.opj"> and <SelectPMItem "./mytest.dsn">, and catch the error, it report errors with "RuntimeError Item Not Found" frequently. Is there any Tcl Command that implements this function?
3.When I save the project or library after modify with the code blow, It will pop up a window that needs to be confirmed, but I don't need the step, I want just save it directly.
# the code use this:
DboSession_MarkAllLibForSave $lLibSession $lDboLibrary
DboSession_SaveLib $lLibSession $lDboLibrary
# the confirm window like this:
  • CadAP
    CadAP over 1 year ago in reply to Morgan +1 suggested
    HI Morgan, Please dump list value "$ lDesignloc", then check correct output is stored in the variable "lDesignfromIndex". Also check "lDesignName" variable is storing correct value. I think somewhere…
  • Morgan
    0 Morgan over 1 year ago in reply to CadAP
    Hi CadAP,
    I use V24.1, and open 5 dsn files.
    With your code, it just process the time minimum dsn file, if I modify variable lTimeIndex, such as "set lTimeIndex 3", the code always not work(can't switch to that dsn window), and if I add SelectPMItem "./$lDesignName" after ui::PMActivate, if always fail and print message:RuntimeError Item Not Found.
    The last few lines of code I modified were:
    #set lTimeIndex [lsearch $lDesignTime $lLastDesignTime]
    set lTimeIndex 3
    # puts $lTimeIndex
    set lDesignfromIndex [lindex $lDesignloc $lTimeIndex]
    # ui::PMActivate "$lDesignloc"
    set lDesgnLoc [split $lDesignfromIndex "\\"]
    set lDesignName [lindex $lDesgnLoc [expr { [llength $lDesgnLoc] - 1}]]
    if {$lDesignfromIndex != ""} {
    ui::PMActivate "$lDesignfromIndex"
    puts "/$lDesignName"
    catch the SelectPMItem message, print like this:
    So the issue is, can't process other dsn file name but the time minimum one, can you help me solve the problem?
  • CadAP
    0 CadAP over 1 year ago in reply to Morgan
    HI Morgan,
    Please dump list value "$lDesignloc", then check correct output is stored in the variable "lDesignfromIndex".
    I think somewhere variable are messing up with the values.
  • Morgan
    Hi CadAP,
    When I puts this 3 variable, see command log as follows, Looks like nothing is wrong.
    Now "set lTimeIndex 4", get the dsn name T5.DSN, but Actually PMActivate the dsn file T3, and SelectPMItem it failed.
    #this is command log
    Capture> source [file normalize {G:/Cadence/Work/GetLastOpenedProject.tcl}]
    lDesignloc: {G:\CADENCE\WORK\TEST\T1.DSN} {G:\CADENCE\WORK\TEST\T2.DSN} {G:\CADENCE\WORK\TEST\T3.DSN} {G:\CADENCE\WORK\TEST\T4.DSN} {G:\CADENCE\WORK\TEST\T5.DSN}
    lDesgnLoc: G: CADENCE WORK TEST T5.DSN
    lDesignfromIndex: G:\CADENCE\WORK\TEST\T5.DSN
    lDesignName: T5.DSN
    Capture> ui::PMActivate "G:/CADENCE/WORK/TEST/T3.opj"
    Capture> [ 1]RuntimeError Item Not Found
  • Morgan
    Hi CadAP,
    I puts this 3 variable, all the values look like not wrong.
    Now "set lTimeIndex 4", get the lDesignName T5.DSN, but Actually PMActivate file T3, and SelectPMItem failed.
    #the command log as below:
    lDesignName: T5.DSN
  • Morgan
    Hi CadAP,
    lDesignName: T5.DSN
