  2. Allegro X Scripting - TCL
  3. How to select a project and save it with Tcl Command
  • State Suggested Answer
  • Replies 15
  • Answers 1
  • Subscribers 14
  • Views 7916
Morgan
Morgan over 1 year ago
Hi friends of the community,
I want to use Tcl Command to select the last opened project name(or library) in capture cis, such as .dsn(.olb), and then, save and close it, but I encounter some troubles:
1.When I iter all open designs in the session with 3.2.5, it get the design name, but not listed in the order in which they were opened, so I can't find the last opened project; and sometimes, it listed the project name I have closed;
2.When I try to select the .dsn or .olb name use <ui::PMActivate "d:/cadence/work/test/mytest.opj"> and <SelectPMItem "./mytest.dsn">, and catch the error, it report errors with "RuntimeError Item Not Found" frequently. Is there any Tcl Command that implements this function?
3.When I save the project or library after modify with the code blow, It will pop up a window that needs to be confirmed, but I don't need the step, I want just save it directly.
# the code use this:
DboSession_MarkAllLibForSave $lLibSession $lDboLibrary
DboSession_SaveLib $lLibSession $lDboLibrary
# the confirm window like this:
  • CadAP
    CadAP over 1 year ago in reply to Morgan +1 suggested
    HI Morgan, Please dump list value "$ lDesignloc", then check correct output is stored in the variable "lDesignfromIndex". Also check "lDesignName" variable is storing correct value. I think somewhere…
  • Morgan
    0 Morgan over 1 year ago in reply to CadAP
    Hi CadAP,
    I have opened 5 dsn file, and puts this 3 variable, all the values look like not wrong.
    Now "set lTimeIndex 4", get the lDesignName T5.DSN, but Actually PMActivate file T3, and SelectPMItem failed.
    #the command log as below:
    Capture> source [file normalize {G:/Cadence/Work/GetLastOpenedProject.tcl}]
    lDesignloc: {G:\CADENCE\WORK\TEST\T1.DSN} {G:\CADENCE\WORK\TEST\T2.DSN} {G:\CADENCE\WORK\TEST\T3.DSN} {G:\CADENCE\WORK\TEST\T4.DSN} {G:\CADENCE\WORK\TEST\T5.DSN}
    lDesgnLoc: G: CADENCE WORK TEST T5.DSN
    lDesignfromIndex: G:\CADENCE\WORK\TEST\T5.DSN
    lDesignName: T5.DSN
    Capture> ui::PMActivate "G:/CADENCE/WORK/TEST/T3.opj"
    Capture> [ 1]RuntimeError Item Not Found
  • CadAP
    0 CadAP over 1 year ago in reply to Morgan
    Hi Morgan,
    Can you just clear variable lDesignfromIndex (set lDesignfromIndex {}) before setting it?
    This might help you get the correct value.
  • Morgan
    Hi CadAP,
    Thank you for the idea, but the result results does not change.
    Maybe this is the V24.1 bug, I test in V16.6, this problem did not occur.
    And I find one new problem, just use proc "atime", but can't use "mtime", it not work.
    set lDesignfromIndex [lindex $lDesignloc $lTimeIndex]
  • CadAP
    Hi Morgan,
    I used "file mtime $lDesignName" in spb24.1 and it's working.
    Can you please check and let me know spb24.1 hotfix?
  • Morgan
    24.1 S003 (4280230)
